What have you done to your 200 Series this week?
New cup holders. 👍🏻
Posted on my build thread but...
Installed 2 Prinsu load panels and maxtrax pins. Panels were pretty simple. Pick the bars to run the panel between. Remove screws completely on one side of bars and loosen on opposite side. Lift 2 bars on side with screws removed and slide the panel in the channels between the bars.
Maxtrax pins need/could use washers under the top side as the panel sits below the bars and so the maxtrax don’t sit all the way onto the pin.
Stock Tires .....typical 21/2” puck style front strut lift...leveled it out nicely need to leave it alone for now as it rides and drives as it should...my wife is driving it for the next few years and she loves it. The shop that did the lift was not familiar with the KDSS system so I had to bring it home, pull it in my shop and correct the “list” that developed when installing the lift....took me a whole 7 minutes after going on line and reading about the correction that is typical when working around the KDSS system....thanks for the reply
Received and installed a set of Tyrant E-Boards, ordered them on Monday from Australia and received them on Friday via DHL Express....1,500+ delivered to my door. Nice product very heavy duty. Motors on all four mounts, boards are much heavier than an Amp Research board (not available for the 200 series LC), motor mounts are very heavy as well. Tyrant uses an older technology, contact switches at the B piller and small magnet at the door. So we had to run the associated wiring through the thresholds and work our way up the B piller....Amp uses direct wire in the kick or OBD2. While we had the thresholds and panels out we ran wire set (ARB) to the back for a fridge. We also installed the Redarc Tow Pro Elite brake controller....slick....easy plug and play.
So, I did a thing....Took the 3rd row seat and plastic siding out. I'm hoping to find a way to mount a an ARB twin compressor...not looking too good. Also, I'm going to run/mount a Weboost Drive Reach back there as well...Wish me luck!
ARB sells a bracket that mounts a twin compressor AND a tank in the right rear quarter. It requires the removal of the OEM sub though. I know @cruiseroutfit has more details if interested.
Installed GROM vline2. Apple carplay and android auto!
L
Link? Are those the factory button controls?
Yeah, I saw that but I don't want to give up the sub :(
Having been inside that panel a few times, I think your only choice then is to just slap it on the outside of the truck with some sheetmetal screws and Liquid Nails.
Yeah, I'm looking at the spare tire bracket as a possibility. I'm still going to mount the Weboost in the rear area, so it's not a total loss.
What if you gave up the little cubby where the jack is stored?
Is that compressor rated for weather exposure?
That is the plan and I'm going to take measurements of tonight. That cubby extends to the sheet metal, so there is a possibility that it could sit in there sideways. I just need to make sure there is enough space for a fuse block and such. So, I'll play around with some cardboard and see.
Started playing with @TrekboxX dividers thanks to @Overland Tailor's great instructions. Found the perfect bins at Sam's club (Link here). You can stack 4 high perfectly in the large drawer and very practical. I use my 200 as a daily so I'm focused more on daily functionality than great looks so it's not a pretty as others.
Got my front windows tinted for a better match with the rear OEM tint.
Added Bora .75" spacers. Torqued, drove around, pulled wheels back off and checked torque again - no change but a pain in my back even with the
At some point, the vehicle weight is going to meet or exceed weight limit of that lift and will then change to jack stands.
Really want to install my Jowett Performance filter housing with Fumoto drain valve but Toyota has given me 2 free oil changes in the last 3k miles. Don't ask ;) Will add in 5k miles.
Removed the front mud flaps while at it. Why with these OEM wheels? Waiting on my Rhino front bumper to arrive next week. Once I get it installed, I'll order and mount some bigger tires on my OEM wheels (a decision that I've spent way too much time thinking about - RW 17 vs Heritage BBS vs stock). Probably going 34" Ridge Grapplers or maybe 33" Falkens. Just trying to plan ahead and avoid any rubbing. Will most likely go BP-51 route later this spring or summer.
Thanks to Matt for all his write-ups and feedback on Ruby. Appears his 34's cleared prior to suspension upgrade and he recommended to get your choice of tires first before installing & dialing in the BP-51's.
Sporadic purchase of a Pedal Commander, after reading feedback from @mcgaskins
Just starting to try it out, but does make a nice difference in Sport setting. May decide to hide the controller and just use the app on the iPhone.
Gradually getting there.... Bud Built rock sliders ordered and in the long queue for delivery.
40" light bar ordered and 8 week delivery date.
Thanks to @WildYoats for his assistance in sourcing the mounts again AND years later after his install. Good on ya.
Really appreciate all the great feedback and support of the Mud forum members! Great community but rough on my wallet.
Did you shave studs to get .75 spacers to work or replaced them?
Be careful with pedal commander. It doesn't do anything beside remapping pedal travel so in sport at 50% pedal press is like normally at 100%. so no difference between 50-100% press. Pretty much you are hammering engine and transmission every time which long term who knows what the impact is. You can accomplish the same if your seat is position correctly and you are working full gas pedal but with more control and when you needed vs all the time. BTW tried it myself on two trucks (LC and 4Runnner) as believed the marketing BS. Sold both of them quickly.
I didn't have to shave the studs. I talked to the folks at Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
They were familiar with the OEM LC specs and custom made.
Thanks for the heads up on pedal commander. It does seem to rev up higher than needed and I'm sure it isn't going to help with MPG's when in sport modes. I'll probably turn off or look at return options. I don't need the extra wear and tear.
Looks like the packets are big enough on the 18" wheels. I have moved to LX570 wheels and need to go slightly over 1.0 to make it work. .75 seem perfect without beating fenders with chips.
