- Thread starter
- #61
I sure wish mine had a USB port......... Wife's 10' Venza does..... my 09' LC does not.
I'm diggin the new H.I. avatar.
Nice work. Really.So I decided hiding the iPond behind the radio was not such a good idea, as it would be impossible to access if I needed to get to it (which I ended up needing to do as soon as I got my dash put back together).
I decided to route the USB cord behind the ash tray, up through behind the radio, down the outside of my glove box, into the area where the cabin filter is accessed and then out into the glove box itself. Now, I can keep my ipod connected from inside my glove box.
You could have gone that extra yard MS and installed a matching wood grain cord. I'd bet your wife will agree.......So I decided hiding the iPond behind the radio was not such a good idea, as it would be impossible to access if I needed to get to it (which I ended up needing to do as soon as I got my dash put back together).
Would a 2009 model LC have an USB port on the rear of the stereo? If so, I like where this is heading......
If so, then my next question will be if it's as easy to get to the rear of the stereo as it was with my 100. I could have its stereo pulled out inside of 5 minutes.
love it, that's my next mod!!!Oh boy. Must haz.
Does the retractable charge and play? Brand/specs?
That's slick.
Not as cool as others but the cup holders are slick plastic on the bottom and even with cup adjuster my bottles would tip easy. Also misc things slide around so cut some non slip padded tape and matched to the bottom. Here is top side done so u can see difference. Now everything stays right in place. Made mistake of not flipping tape over for other side mirror effect. Doh View attachment 947428
my guess is he took it out to do the mod and will likely be putting it back in, the three click ratchet system to hold the coffee cup is about the worst design I have seen for a cup holderGood idea.
But here is a question: Where is the insert that goes between the two cup holders? There should be a plastic piece with two adjustable arms that hold each drink and keep them from tipping over. If you had that, you wouldn't have to worry about rubber.
