Yeah, don't think you can dig this out.
I gots no crawl or kdssJust turn on the CRAWL control. You'll be fine.![]()
Look on page two of this thread. Pics on thereIs that the vpr bumper? Can u send a pic of that?
Yeah I had thought it was the windshield trim too. I am still trying to get it solved. I may try graphite like you, next.
Yes it is.
tried winching a fallen tree and have it bury itself but that failed as it would just dig in and then rotate up and over even while trying to guide it, the other half handled the winch beautifully even though it was her first time, while i looked around to find another way to position the log she walks off and then asks: how far will the rope reach? I answer it's long but won't go too far and i look up and see her pointing to a tree and telling me this is solid enough. I start to argue that it's at too much of an angle also I'm skeptical of if it'll hold up. I cut myself short walk over, have a look, give the tree a good kick and think what the hell what can i lose, tow strap around the tree, rope shackle between the the winch cable and strap and let's go. I was in for a surprise. The 200 was buried and i wanted some bit of tension and support to help it crawl out of the hole it dug... It freakin rotated on a dime and then started lifting the cruiser up and out.icon makes several kits for the 200 series, none of which are listed on icon's website nor on anyone else websit for the matter, if you call icon directly they'll tell you what they offer, i'm sure if you contact the vendors and give them the part no's they can order them for you as i'm sure they don't stock most items and drop ship them directly from icon. they start at a stage 1 all the way to stage 4. stage 4 has front coilovers with external reservoirs, 2.5" pistons and compression dampening control valve(CDC), rear shocks with piggyback reservoirs with CDC valves, and rear trailing links, the stage 3 is the same as the above without the cdc valves, the stage 2 does not have the cdc valves or external reservoirs in the front, stage 1 i believe is just the 2.5" coilovers no valves or reservoirs
stage 4 part no is k53074
stage 3 part no is K53073
