What have you done to your 200 Series this week?
Where's the best place to get some OEM/OEM quality shocks? Guessing I don't need to pay toyota dealer prices for Bilsteins. I have one leaky shock on my 2013 so I think they're all original
Factory dampers are actually quite affordable. The rears were under $60 each back when I got my rig, though that was a number of years ago.
Installed this a couple months ago. A must for every owner.
I laughed at how affordable it was.
I could have gotten another $150 or so off with the 25% and free ship, oh well.
If you’re replacing the shocks, please replace all the bushings and the top mounts, too. It’s not too much more cost, and no more labor.
I can’t remember if the 200 series shocks come with new rubber and hardware. Some of our stuff does, some doesn’t, hard to keep track.
Check out the executioner pro mosquito killer on Amazon. This tennis-racket shaped thing vaporizes them... no BS, they'll explode. Quite entertaining.
Not a totally new concept, but that one is built solidly enough for camping.
Just got mine. OMG what a blast, literally and figuratively. :bounce:
Took it to my buddies shop so I could borrow his lift and swap in the new OEM shocks and springs but the front springs are designed so tightly wound, the wall mounted spring compressor feet didn't fit between the coils. Guess I'll be doing it on the ground with a rental tool, the old fashioned sketchy way.
They are tight.. I have found even the rental tools sometimes have to be unthreaded to sortof scoop the female threaded end through the coils then start compressing.. a good impact gun really cuts down on the effort of this job.
Make sure to wear safety glasses, impact resistant gloves, a crash helmet, a cup, a set of hockey breezers, and football pads when you do it. And ideally keep your body behind a sheet of AR500 plate the entire time.
Starting to install some wiring for a DC power supply and for something else so I made a mount for the breakers. I drilled an additional hole (4" on center) in the battery clamp so to mount a piece of 1/4" ABS (5" x 6").
After wiring everything for the DC power supply. Note the ABS plate attaches to my drawer system via two magnets.
37s, no body lift, full up travel? 🤔
