Replaced my front, upper console (58804-60131) today. For the past two years I had my old one covered with double-sided tape and black fabric which looked okay but I figured it was time to just replace it.
One thing to note, it came with the updated cupholder style with the larger recesses and butterfly cupholder thing. Now if only I could figure out how to remove the shift knob and replace the awful looking shifter surround...
Old style:
Old console with fabric cover:
I did this a few months ago on the '03 LC. It's amazing how the new console make the truck look several years newer inside !!
Same model number? My '03 LC console is scratched up, that pic above looks great. Just not sure it will fit the same in an '03...
03-07 is different because they're painted silver.
58804-60131 for 98-02
58804-60132 for 03-07
Thanks - other than color are they the same? I far prefer the black over the silver...
As far as I know they're exactly the same except for the color.
Apparently the cruiser is good for domestic stuff too. Who knew? Yep. That's a piano.
Convenient, not really. Secure very. Rack is secured down to rear tie-down locations with extended bolts, and in the front by 3rd row oh sh!t handle locations with extended bolts. Hi Lift is secured onto rack with a locking bracket that is reinforced by uprights I built into rack system. Tretiary it is secured with a strap. If it comes to me actually having to use the hi-lift then I have bigger problems then worrying about access to it.
@bwell Are the 2nd row seats still accessible with that rack? In the photo's you have them folded down but I didn't know if you just had them that way at the time or if you have to keep them that way due to clearance issues.
The 2nd row is completely usable still. There's another shot of them locked up right.
This is a 6mph crash. That hi lift is directly behind the headrests, and the headrests are in the lowest position. Again, IMO, super scary and seems very dangerous.
I removed my rack, rear wind deflector and sunroof deflector as well as the running boards and thne cleaned her up and gave it a coat of wax.....
Tried to test fit a 325 on a FN rim but about 20mm to far out..... looks like 18x9 Et 35 is the optimal.....now to find something the I like ...
Pulled the running boards = 4 broken bolts. Love rust!! Looks great without the running boards attached. Maybe I'll do sliders at some point in the future.
Also installed pfran interior LED kit + reverse LEDs. They are AWESOME!!! I did have an issue where none of the door LED's would seat properly. Had to get creative and bulk up the leads, seems to have done the trick. Also, as a little FYI, If you use one red reading light LED up front you have a 2 extra white LEDs that can be used for the license plate lights.
Could you tell me how much that cost you? I got a little crazy with the heat gun while removing my "wood" trim :(
$297 and from Mid Atlantic Toyota Parts, price went up recently though to $321.
Conicelli Partznet has it for $283.
You can also ask Beno or CDan.
