PFran LEDs = night sun inside the 100! I love this $50 half
mod.
mod.Follow along with the video below to see how to install our site as a web app on your home screen.
mod.details.......PFran LEDs = night sun inside the 100! I love this $50 halfmod.
Thx!details.......
Pictures?285/75r16 Goodyear Duratracs. Wife says they look good! I'm in good shape.
Finally (!) finished soundproofing the lower half of the LC.
Before
After (below) - Decided to keep the vapor barrier intact and only added a few strips of Dynamat to the outer skin and some BAM around the speaker edges. I noticed that there was some dust around the edges of the door. Looks like the plate for the speaker is about 1/4" too thick and causes a gap between the door panel and metal. No big deal though since I used the BAM to fill the gap. All in all, something this simple just "tightened" up the sound (e.g. fewer unwanted noises).
Before
I have always thought about doing something like this but I can never tell whether it's going to make a huge diference, any input? My LC is stock but might be getting some louder tires soon (hence the inquiry). Also, how much Dynamat did you end up using for all 4 doors? Any other areas where you would recommend applying it (without taking the entire interior apart)?
Looks good man, thanks!
Looks great!
What model # Focal did you go with? Did you use one of their component sets up front?
I just bought a MegaPack of Dynamat Xtreme (72 sq ft) and was thinking about also buying their "Step 2" product (Dynaliner) which is a thin adhesive-backed foam for doors, floors, etc. It might be a good alternative to the factory vapor barrier, while helping to eliminate rattles and tighten up the fitment of the door panel to the metal doorskin....
It comes in 1/8", 1/4" and 1/2" thicknesses so one of those is sure to be a nice snug fit. It's WAY cheaper than the Dynamat Xtreme so I don't think I'll feel guilty about buying some just to try out in different places. I want to make the interior of my LC REAAAAAALLY QUIET, and kill all the weird little rattles and squeaks that have developed over the last 14 years.
-G
I have same set up, with SPC arms. A bit a rub st full lock, am not concernedAny issues with that setup, I'm looking to do the same soon.
The front doors have component K2 Power 165 KRs installed and the rear doors have Access 165s installed. I still need to get a sub in the rear and am probably going to get a JL Audio set up behind the second row seats.
While I went "all in" on using both Dynamat products (Extreme + Dynaliner), it was definitely overkill. There are other products that accomplish the same thing - if not better - for less $ (Sound Deadener Showdown). I do like the "fit and finish" of Dynaliner though and if I were to choose just one of their products to use, that would be it.
HTH
That's great info. I may be taking the carpet out to give it a good scrub this summer and while I have that out I was thinking about putting in some Dynamat as well. I figured that the doors would be the easiest to access but center console and foot wells being worth the time as well.
Is it just a waste of time to bother with the entire cargo area? I figure if the carpet is off for the rear wheel wells it might make sense, but I can't imagine that a lot of road noise carries up to the front from back there.
How big of a difference did this make for you?
