285/70/R17 (C Rated) so just 33's. I didn't want any bigger. I was actually surprised that Discount Tire was able to get them within just a day or two. I think size choices are still limited though.Nice! So the KO3s are out? What size did you get?
Do you rub on the front mud guards?AHC set at normal.
Replaced the fuel filter. Pretty sure the original was still on there at 260k. I’ll get to the fuel pump and sending unit when those parts come in View attachment 3582387
Just did the AHC shock spacers, relocated the eye level of the rear sensor link using an aluminum bracket and a 30mm coil spring spacer from Ironman. Also decreased the tension on the TB bolts to get back to factory pressures in front.
For those who still have an aftermarket diff drop or those who removed them, what are your thoughts and first hand experience? Not sure if I should be worried because of a now more aggressive CV angle.
Regarding the AHC strut spacers…Just did the AHC shock spacers, relocated the eye level of the rear sensor link using an aluminum bracket and a 30mm coil spring spacer from Ironman. Also decreased the tension on the TB bolts to get back to factory pressures in front.
If you’re happy with the height you’re at and you’ve gotten your AHC all adjusted, I’d definitely recommend a diff drop. That’s a lot of angle on your CVs and you’re going to be tearing boots and/or throwing grease out every time you turn around even with OE axles and boots. Ask me how I know…View attachment 3582536
Yes that teflon locking nut for the lower mounting bolt of the spacer sure is close to the boot, I will have to inspect this today. And that third securing bolt will definitely be installed, thanks for the heads up I appreciate it.Regarding the AHC strut spacers…
If you do the AHC strut spacers, be sure to check for CV boot clearance to the strut spacers brackets. Mine would almost touch the CV boot at full lock, on both the left and right side fronts…
So, at the point of contact, I shaved down the shock extension brackets with a flap disc, and welded through to fuse and laminate the 2 layers of steel in the bracket. Sadly, in this process, I lost the zinc plating on the shock extension bracket in that location, so I ended up prime and painting them black.
In the photo, you can see where I changed the radius in the lower right corner of the shock extension bracket. I now have 4mm clearance to the CV boot at full lock.
Thank you, I know they may all look the same but what's everyone using for the diff drop bracket? I have the Dissent skid plate, is that going to be an issue?If you’re happy with the height you’re at and you’ve gotten your AHC all adjusted, I’d definitely recommend a diff drop. That’s a lot of angle on your CVs and you’re going to be tearing boots and/or throwing grease out every time you turn around even with OE axles and boots. Ask me how I know…
We hit La Choza frequently, it’s the sister restaurant to The Shed. We love it. Our favorite is Cafe Pasquale for breakfast.Thanks! It's a nice spot for sure - hope you guys hit La Choza on your trips here! Durango is a great spot too, love the MTB riding up there and hoping to make another trip up next summer.
If price is a concern, search in eBay. There r a couple of good options from ausi, cheaper including shipping to USA.what's everyone using for the diff drop bracket?
Rear brake job with a few surprises...I was doing the brakes because a bad grinding noise started that I assumed was worn pads. It was really bad though with constant drag on the brakes it felt like so I thought it might be bad. Was surprised to find this. Caliper pictured is exactly how it was when I pulled it out...anybody spot what's missing?? PO had said he had done a pad change recently so it seems he wasn't the best mechanic. Oh and the other side the rear axle seal is leaking...I'll have to get that done another day. View attachment 3583982View attachment 3583983View attachment 3583979
What was wrong with the valve? I have one sitting on the shelf that I plan on installing in the next month.Wow, never seen a missing pad before!
I just changed the oil, new air filter, and lubed the drive shaft. In the process I removed the Fumoto valve I had installed a year or two ago. It began leaking and I couldn’t get it to stop. Back to a regular drain plug now, no leaks.
I don’t know. It worked fine for a while, but after a couple oil changes it began to leak. I tried retightening it, but no luck. A buddy of mine had the same experience.What was wrong with the valve? I have one sitting on the shelf that I plan on installing in the next month.
Report back after a few tanks and let us know if you experience any fuel smells or any shortcomings to the modifications used to make it fit the later modelsWrapped up the 40 gallon replacement tank today. Took a week to do working on and off as time allowed. Everything was replaced, new fuel pump, sending unit, fuel pump bracket, cushion, filter and hoses. My only complaint are the instructions and information provided. The instructions cover 98-02, but fail to mention that there are differences in the 03-04 fuel pump brackets and the routing of the rollover valve. If you are looking into this tank for your 03-04 LC/LX, expect to modify the plate that holds down the fuel pump bracket and more fuel line will be required. Aside from that, really looking forward to more driving and less fuel stops!
