Cary, do you know anything about the Walmart SuperTech synthetic? I use the 10W30 in the 5 quart jug for $13. A hell of a deal, and priced about the same as some high end dino oil.
A delayed thanks Cary!....I installed the 0w-40 Mobil 1 in October and have used less than 1/2qt in 5000km... so I am now about due for another change....I would be very happy to use the Mobil 1 0w-40 again ... but can't find any locally. Haven't found any of the 0w-40 Rotella synthetic either...but haven't looked to far.Good oil but there is no need for you to run it. For most engines, wear decreases as oils get heavier, up to the high 30 weight/low 40 weight point (see the oil faq for a discussion of weight spans). After that, unless there is a specific reason to use it heavier oil simply robs power and mileage. I see no reason to run the 5w-50 instead of 0w-40 or the Rotella 5w-40 (actually since you are in Canada you get the Shell Rotella Synthetic 0w-40 which is better than the Rotella we get in the US).
the 80 is bulletproof. I decided not to waste money on synthetic and am happy with dino chevron 10-40 (or whatever) w/ 2-3k intervals-I consider that anal for this truck.
This truck has a 8L capacity! That's alot of frickin oil! I bet the only time the engine sees any wear is startup and even w/ cheap, crappy oil it prob makes little to zed difference if you are fanatical enough to be on this forum. JMO
I think just get a lighter weight for cold season startup
no, most of my driving in the 80 is offroad. I'm changing it 3k no matter if it's dino or syn.
Any thoughts on the Chevron 10-30? I figured all the name brands are pretty good now and at $19.49/case at Costco it's best deal I can find.
Live in Phoenix, AZ
That 10w-30 Chevron is a good oil, but the Delo 400 15w-40 you are already using in your Damlier-Benz is a better oil, especially given your climate. The nice part is you only have to then keep one oil on the shelf.
