Old plugs pulled, #5 looks suspicious. Tell me what you guys think.
What do my spark plugs tell you?
At least they weren't Champions!That the purchaser was willing to compromise, didn't step up to Denso!![]()
I would not go discounting NGK Iridiums over Denso Platinums.
That's 80s tech vs 2000's tech.
You also do not gap the new plugs. They come to spec, and it likely has to do with damaging the center electrode.
So I gapped mine becase:
a) the factory gap was .8mm (I think)
b) the gap wasn't right on these plugs that I bought: Amazon.com: Toyota Genuine Parts 90919-01176 Spark Plug: Automotive
I was a little confused because the FSM says one measurement, but then a bunch of folks on here say "don't worry, just use them as they come". I went with the manual's spec.
thanks everyone for their replies. I haven't driven in a while as I work at home and my Crusher mostly gets covered with tree pollen these days. which makes me a bit sad.
update; plugs were replaced and some weird stuff happened.
let me back up just a little bit; this all started when i stupidly washed the engine bay and then I developed a misfire (lesson learned). my first inclination was water in the distro. As it was due for basic tune up, I replaced the plugs, wires, distro cap, rotor. all brand new. checking the engine codes, it showed running rich and throttle position sensor codes. I replaced the TPS with a new one, pulled the battery for a while to reset everything and hoped for the best. nope. womp-womp. same behavior. Still misfires, runs rough and smells like there's unburnt fuel in the exhaust.
I drove it around a couple miles again to try to get it to fire off another CEL and eventually it did. again, running rich and TPS sensor codes.
I pulled my #5 plug and took a closer look at it as I've suspected this cylinder was being a jerk.
if you look closely at the new plug, it looks like the spark has been jumping though the white insulator .
why would this happen?
