- Thread starter
- #1,161
@clrussell what diff’s are you running…. With my 2F and swapping the 3.70’s differentials I have about a 20% drop in rpm along with the 31” KO2 tires
4.11 gear. 35” tires.
5.3 LS engine. 4 speed trans
I thought about washers. It seems more like a bandaid. However with the planned front suspension changes maybe that’s the best solution.You can install large washers to fill the gap or find bushings with wider shoulders.
I shortened my shackles a little to help get a better castor angle. It helped a little bit. I eventually installed 6* shims. I run 4" skyjackers and have about +3* castor. Keep in mind longer shackles are required for lift springs. You need to allow the spring to flatten out.
There's nothing wrong with spacers. What's you castor angle?
Is that an actual "problem" though?Also need to figure out how to fix this problem. This is the frame side mount for the leaf spring. You’ll notice the 1/4” gap between bushing and frame.
First world problemIs that an actual "problem" though?
In town or highway?Still driving it 6 days a week. Got 11.3 mpg last
Mostly town.In town or highway?
I haven’t measured mine in a while, but I was getting 17mpg highway with a very similar setup. Realistically though, 11 in town might be deal. It’s a lot of weight to stop and go constantly.Mostly town.
Some highway small trips.
I took the easy way out with mine last year before replacing with those ProCar seats… I just dropped a 1 1/2” steel square tube under the two rear mounts between the floor and the seat mount…, a 30 minute job if your drilling the thru holes and search for a much longer bolt….that was a very nice difference in seat angle and visibility
