What Did You Do With Your 120 Today?
I got new sneakers today! I went with an odd size but should work. Went from 295/70-17 to 34x10.50-17. Half an inch taller, an inch narrower and 10 lbs lighter (per tire). Plus the 3 Peak designation…
Old sneakers.. Toyo OC R/T
New sneakers.. Toyo OC ATIII
A bit cookie cutter.
Nice tires, nice GX, but that view..... wow!
I would definitely enjoy waking up to drink coffee gazing out at that vista
The other night I noticed one of the LED 168 bulbs I installed in the headlamp (parking marker light?) was flickering.
Flickering LEDs bug me so I bought new incandescent ones to replace the LEDs.
Any recommendations on good LED bulbs? I had Lasfits and they only lasted 18 months.
Any "LED kit" for your vehicle on Amazon is going to have cheap LEDs that will flicker and fail within a year or so. I've done that nonsense and I'm through with that. Now, I pay once cry once and get Sylvania LEDs. They have lasted well for me.
Finally installed my "upgraded" window switches, they've been sitting around since November until I had the patience to find the ignition-switched power source. Took me about 10mins to find all 4 doors today lol.
Before:
After:
Night mode sure makes lights look much brighter than they are!
Still haven't gotten around swapping the footwel lights and inner door handle lights.
Oil changed, driveline greased, & front swar bar bushings greased. Went offroad a few weeks back and front articulation was causing a nasty squeak. Used Energy Suspension’s sticky icky icky grease.
Today I neutered our GX. It’s a sad sad day.
Started removing the JWOffroad spare tire mount too which leaves some holes to fill. Thinking I will use stainless button head bolts just in case we ever decide to put the mount back on.
I installed a manifold with gauge and isolation valves to my cheap onboard air setup. I also did the "electrical tape mod" to my guage cluster to cover up the flashing yellow "OFF" from the rear adjustable suspension. No, pulling the TEMS fuse wouldn't have resolved it as I'm one of those poor bastards that gets the Christmas lights if its pulled.
