What did you do to your pig today?
Well it wasn't today but we did take it wheeling at "Cruise Moab" last week.
A couple of days ago I got the broken muffler mount fixed and the exhaust pipe upsized to 2 1/4" all the way back.
Is that rain or snow on your lens?
There was sleet (rain/snow mix) falling in the second picture.
Weird day on Thursday, woke up to snow, started out the run in sun, got some rain/snow/sleet along the trail and then I think I even ran the A/C for a few minutes in the afternoon!
Installed the e brake drum and driveshaft, cleaned the frame behind the fuel/vent/brake lines, drained and refilled the transfercase, the transmission had about two too many pints in it:doh:,pinned the shock mount nuts, re-did the lower radiator hose transition, re routed some heater lines, trimmed the fuse panel w/ neoprene, hooked up the battery and did this....
You did all that work in the ditch?!?! :)
Would have been easier to park on the driveway first!
I just HAD to say that.
Sure feels like I been workin in a ditch. Nice to get out of it for a change!
Went by the body shop today and they are just getting started on the rear corners thats the the only real body work on the rig
WHat happened to your reverse lights? Are they going where the reflectors were?
got a tach now happy was a easy install now got to work on some engine stuff
8k tach - I am guessing you went with something other than the F/2F...
With after market gauges you pretty much take what you're given. The tach on my FJ55 with the 3B goes to 6000rpm but the 3B redlines at about 4100rpm and I rarely get to 3000rpm. Same goes for the boost gauge, maximum boost 30psi on the gauge, maximum that I run, 10psi.
What is 'red line' on the 2F anyway?
lol i have a 92 chevy vortec 350 under the hood. ;);):grinpimp::grinpimp:[/QUOTE]
A vortec with a carb on it?
I was wondering the same thing.[/QUOTE]
Just guessin here, but since I am 98% done with a Ford 5.0 HO (speed density FI) swap in a 76 40, that it was just easier (cheaper and an order of magnitude less complicated) to slap the intake and carb on it...add gas...and go today. Spent a few evenings gazing at my old intake and carb off the old 302...but
I perservered and stuck it out to have the injection.
Nuttin really new on my piggies...Pigwald sees some action and the other is just a pig in the blanket until the aformentioned 5.0 swap goes from 98% to 100%...then add in rear aussie and the 8274 up front. I'm thinking the blanket will come off in mid June for some pulled rust pork action.
