Well, we have hit a snag on the Chinese 1HD-FT diesel pump. The tachometer is not working correctly. It shows a little movement but does not reflect the accurate RPM of the engine. We swapped pins without success.
And ultimately pulled the intake manifold again which allowed us to remove the hall effect sensor on the back of the pump without removing it. Just barely possible.
When we did we found that the two sensors were quite different.
The length of the new sensor, on the left, was markedly longer than the sensor from the old pump. We put the old sensor back in and sadly it did not fix it.
For those of you that have not looked into this there is a wheel inside the pump whose teeth trigger the hall effect sensor.
The old OEM pump is over at Bosch being refurbished and recalibrated for a manual transmission. That should fix it I think, but I would really like to solve this problem. If any of you have ideas we should try I'd greatly appreciate it.
FTs can be kind of weird with the tach.. the ones that came with EGR send the signal from the IP to the EGR ecu and then on to the dash. Does this engine have EGR? And what type of cruiser is it going into?
