Hair dryer held at a safe distance?
Spray with contact cleaner?
Looks great! I need to get my butt in gear so I'll be ready to drop it in!
I pulled the steering wheel and contact cleaned/dissassembled the headlight switch and dried everything with a heat gun to no avail. The twist switch on the stalk was activating a relay directly above the glovebox when the headlights were turned on. I removed the high/lo beam switch and cleaned but couldn't find the problem. ...It's going on the road tomorrow so I tapped the line from the relay that goes hot when you turn on the headlights and sent it to a old school universal hi/lo beam foot switch that a sheet metal screwed to the floor up and to the left of clutch pedal and then new lines to the headlights. They're LED's so the amperage is quite low. It all works now.Hair dryer held at a safe distance?
Had I know I would have brought a spare transmission mount for you. Pretty quick swap at camp with a bottle jack.I pulled the steering wheel and contact cleaned/dissassembled the headlight switch and dried everything with a heat gun to no avail. The twist switch on the stalk was activating a relay directly above the glovebox when the headlights were turned on. I removed the high/lo beam switch and cleaned but couldn't find the problem. ...It's going on the road tomorrow so I tapped the line from the relay that goes hot when you turn on the headlights and sent it to a old school universal hi/lo beam foot switch that a sheet metal screwed to the floor up and to the left of clutch pedal and then new lines to the headlights. They're LED's so the amperage is quite low. It all works now.
... Also on this post is a picture of my cross member rear motor mount. Rubber separated on the original mount from a hard bottoming last year. A diagnosed and confirmed the separated mount less than a week from the relic run so it wasn't feasible to order a new factory mount. I managed to get a pair of Cadillac hydraulic motor mounts and make them work. Cutting and welding and modifying but I made it work. Would rather have done the factory setup if I had time.
It will be interesting to see how many 70 Series make this years lineup.First arrival’s at the Relic Run…View attachment 2974232
Maybe I was thinking I would hear higher numbers since your on smaller tire, but the 2.8 makes more power, and you have more weight,,,,,,,,,,
I swapped a 4BD1T in my pig on 37's and was impressed to be in the mid/upper 20's. I would love to get another 4BD1T and swap it in my Troopy.
Yeah but a loaded down troopy is over 6,000lbs. I'm happy with the economy numbers.![]()
How thick and what type of steel, welder and weld wire did you use please? Fantastic job.After rust repair, hot-dip galvanized and painted the 75-frame.
View attachment 2720391View attachment 2720395View attachment 2720396View attachment 2720397View attachment 2720398
ThanksHow thick and what type of steel, welder and weld wire did you use please? Fantastic job.
beautiful, shielded or core flux?ThanksIt's a 5 mm thick standard steel plate, S355 quality, if I remember correctly. The welder is 250 amp MIG with 1 mm wire.
I use CO2/argon shield gas.beautiful, shielded or core flux?
Ya know, I thought my reply might been taken slightly different than i meant it, I'm in agreement.
What's your fuel capacity? Dual tanks? Bet that fill-up was painful.
