If anyone is free tomorrow I could use a hand with moving and skinning my camper.
Sorry dude be working on my youngest man Cubs third GEN 4RunnerIf anyone is free tomorrow I could use a hand with moving and skinning my camper.
What time were you thinking? I could probably run over for a bit and lend a hand.If anyone is free tomorrow I could use a hand with moving and skinning my camper.
Some pretty decent gains
I have been watching that, just have not pulled the trigger, but looks like I need too!
Dang Chris! Betsy and I have been watching videos of those little tear drop trailers for the past few weeks. I think she really wants one or to make one. I will have to pick you brain one day on it. I will be working and on call, but let me know when you plan to do it, I might be able to stop by.If anyone is free tomorrow I could use a hand with moving and skinning my camper.
I decided to jump and be the test dummy on this because of my front left window issues even after replacing run channel, window motor and lube. It's immensely better but not on the same range as the other windows. I'll eventually go back into that window and make adjustments. Perhaps replace the window regulator.I have been watching that, just have not pulled the trigger, but looks like I need too!
Where does one find this magic device? Now that we are back into cold season I was quickly reminded that I need to tackle my 80 window woesI decided to jump and be the test dummy on this because of my front left window issues even after replacing run channel, window motor and lube. It's immensely better but not on the same range as the other windows. I'll eventually go back into that window and make adjustments. Perhaps replace the window regulator.
The real mvp
Nice sticker
Got a lot done today. Most taken apart the cruiser has been in terms of all the different parts to work on. Removed passenger LCA (torsion bars suck!!) and pressed in a new ball joint to the (new) arm. No issues. Painted that and ready to be put back in.
Removed drivers side UCA and pressed out old ball joint. Going to tap and install greasing zerk to the new ball joint for future maintenance. Got all the parts I need to start the diff project so I will be working on that before thanksgiving.
LCA was missing some material where the ball joint was so the bj was not tight in there. I could spin it by hand.Was there something wrong with the LCA?
