What are you working on?
Yeah I knew it but she gone.... rebuild will have to happen. Trying to do this as cheap as possible. Maybe a locker
You definitely need to hang that ring gear on the wall no matter what you do. That s*** is a trophy
I like the idea and I'm onto something similar with a guy local to Richmond. Will let you know what happens with it.....
Did you find a parts truck? i am needing a non rusty rear hatch. Or alot less rusty than mine lol
The deal fell through sadly. Will keep you in mind in the future though.
Snazzy gas strut lifted hood now! Opens a little wider too. No new holes in the truck, just drilled out a couple rivets to harvest that top bracket from the pretty wimpy factory spring. Only hiccup is that it wants to be open so bad that the secondary release is a little tight.
Super nice! I just screenshotted another thread of this before seeing yours. Look forward to seeing in person I already have the struts to do the project!
Basically new steering system in the 100. The rack was replaced by the PO about 5 years ago so. I should be good for a while.
This wasn't as easy a Job as I expected. Getting the old lines off and the new ones on the rack side were a real pita. Also the vacuum switch that goes on the pump needs to be super tight. I was afraid to wrench on it too hard and atf was pissing out from it when I started it. It was fine after I reefed on it though.
Next up. valve cover gaskets. They are basically an emergency. While I was watching it run and looking for atf leaking I could see oil weep out from the vc and hit the exhaust.
I'll try to tackle that this weekend. Pray I don't break any.
You got this! My neighbor just pulled his engine bc he broke the worst one!!! You can do it lol
with the proper drill and bits, all can be done in the engine bay. Try to clean the backside of the lower bolts with a brush and smear some grease on them to help lube them out. work them in and out.
Oh and cut the ps lines and use a ratcheting wrench.
Thanks. I'll do that.
I used a crow foot for the ps line. It worked but wasn't fun
I’ll be out of town on my bumper retrieval / work trip next Tuesday, but glad to show ya any time. I looked at a few of those posts too. The HJ61 body holes in the engine bay were a little different than the FJ posts I saw. That changed a couple things, but otherwise a piece of cake.
