What are you working on?
Adjustable height Awning on. Getting closer
If you are going to take this off road any, I would add two angles, from the tongue to the 2nd crossmember, too help twist on the tongue
Should probably do this anyways. Will give it a lot more structure no matter where it goes.
So im taking apart my turbo and the compressor wheel has a solid little chunk out of it that I dont think is factory. Looking at this replacement wheel, what do you guys think? Any balance issues that might come from this? Also they sell a "6x6" fin wheel, anyone think there would be any benefits or draw backs from going with the 6 fin rather than the factory 5 fin?
From the little I know about turbos. The less fins the more whistle a turbo will have and more on the top end. The more fins the turbo will spool up quicker and be a bit quieter.
Wasnt planned for a trail trailer but cant hurt to throw them on there. Also the plan is to lengthen the tongue. Too short right now for my liking. Not sure that is happening before Relic but on the list.
Add 2' of tongue and a little triangulated tongue box :cool:
You could put a sleeve on it, butt weld, grind flush and then slip sleeve over and weld that up over it, say 12" long sleeve, 6" over each section, or a 3' sleeve and rosette weld into sleeve section.
You could put a sleeve on it, butt weld, grind flush and then slip sleeve over and weld that up over it, say 12" long sleeve, 6" over each section, or a 3" sleeve and rosette weld into sleeve section.
Like what you are thinking
That will also give me some tongue weight. Im expecting to need some more
Valve cover gasket on the rav 4 and some fresh oil. Tightened up cruiser parking brake for the nth time and pulled a nice rock out from behind the disk brake. Rear pads need to be changed soon.
Also fixed all the abs codes. found the front passenger ABS sensor to be malfunctioning so I replaced it with a spare. Used a little fipg to help the broken tab on the spare (say it ain't so!!!)
I’ll add my 2 cents.
Nest thing I did to my trailer was make the to tongue extendable. I can pull a pin, loosen a bolt, and add 2’ of length for towing. Same procedure to shorten it up for storage or tight trails.
Ended up ordering this short block, once it comes in Im going to swap all the do-dads over from the old one. That seemed like the quickest way to get the back on the road. Ill probably run into a slew of things that need to be ordered and replaced in the process.
Wondering if anyones ever gone this route and if they know of some general parts that will probably need to be replaced?
So far im expecting:
-More than likely an oil pan gasket
-Plastic clips (replace ones Ive broken in this process, and just get rid of the pain in the ass design of some of them for something easier to work on)
-Vacuum tubes and any other soft lines
-Any hardware thats in rough shape
-Any gaskets that didnt come in any of the kits Ive got
Also going to get ahold of an EGT kit and install that in the exhaust manifold.
Any other supporting mods that would benefit the longevity and reliability would be appreciated too.
Pray for me fellas! 🤣
I dont have any constructive advice but good luck man
