ttt
Never seen an 80 with a four banger before. That could be a challenge in more than one way.
Better to go 1HZ (4.0 liter) made for the 80.
Thanks. Now I've seen everything.
I would think that would be a little underpowered for my tastes. Granted, with the right gearing it could do very well.
IIRC the 4bt can easely be cranked up in HP with a simple turn of screw, all you loose is some MPG.
Cranked up to what and at what cost?
You could just about turn up a 4BT to match the power of a Cummins 6BT, and you'd still get better mileage than your gas engine
Mileage is a consideration for me and I like the idea of having a diesel but I would rather not slow my vehicle in the process. What kind of power could I get out of the six if I put the same $ and effort? What if I waited for the cummins v8?
The duramax is still looking very sweet at 300hp/600ft lbs of torque. We should start to see conversion kits for those puppies soon. They can easily be tweaked to north of 500hp.
Because lets assume youve got an auto, thats 4:1 in 1st, and yorue in low range, which is another 2.4, then add in the diffs.after all of that reduction multiplication. Now lets assume you have about a 30% overall power loss through the trans and t-case. Being conservative, youre looking at pushing 7500ft lbs of force going to your driveshafts, and axles. Probably not the best idea unless youre running unimog u1300s or rockwells. Duramax with 500hp, is about 750ft lbs. That sounds smartBecause lets assume youve got an auto, thats 4:1 in 1st, and yorue in low range, which is another 2.4, then add in the diffs.after all of that reduction multiplication. Now lets assume you have about a 30% overall power loss through the trans and t-case. Being conservative, youre looking at pushing 7500ft lbs of force going to your driveshafts, and axles. Probably not the best idea unless youre running unimog u1300s or rockwells.
Thats the reason the big diesels are not a good idea for trucks that play in the rocks, unless you are going with axles and 1410/1480 driveshafts to match.
The 4BT in its stock form will outrun the 80's I6, and do so getting 20+ MPG
That's fine. Want a race?!!!!I don't buy that.
With diesels, it's not about the horsepower. It's about the torque. Don't knock the Cummins 4BT until you have seen one perform. Yeah, it's only a 3.9 but if it can push a 1.5 ton Chevy van full of snack foods, it will definitely push around an 80.
I'll smoke your ass in a 1/4 mile and I'll get over 20mpg doing it!!!!
