So I did a little research.
https://home.comcast.net/~jcmiley/main4btinfo.htm
The 1FZ peak (without mods) is at 360 ft lbs of torque at 3200 rpm. Stock hp is 215 - I suspect I am at 225-245hp at about 4400 rpm with modded exhaust.
The 4BT peak is at 105 hp and 290 ft lbs of torque at 1700rpm.
Although they sound close (sort of) and the 4BT is turning much slower (using less fuel) I see an advantage on paper for the 1FZ. Even with mild mods it looks like the 4BT is just matching the top generation stock 1FZ.
If you talk fully modded the 4BT is at 250hp and 500ft lb of torque. Now it will beat the stock 1FZ. But that still appears to be shy of the Duramax in its stock form. Not sure about the 6BT.
