Well, &$%#! Need some advice quick.
Started hearing a noise over the weekend and crawled under and saw this, this morning.
Ordinarily, I'd take it up to the shop to get it fixed NOW. But I have to drive the cruiser Asheville, NC on Wednesday (2.5 hr trip).
Questions: It's driving ok right now. Am I dumb for wanting to drive it up to Asheville and getting it fixed there?
If that's a possibility, anyone know of a good place in Asheville that can get this done with a good turnaround time? (i.e. I'll get them to order what they need and have them do it in an afternoon while I'm up there)
Thanks!
I wouldn't drive it far like that out of fear the front diff will run dry and then real carnage happens. It's a fairly easy fix with simple tools, just messy as hell.
My only concern with trying to get it fixed before Wednesday is that any dealership can't get parts in on time (I don't have the time to do it myself this week, unfortunately).
Likely not a huge deal, check the front diff occasionally, top off if necessary and drive it. It'll be fine for a few weeks until you can get the parts
I am sure there are cruisers that drove with worse for longer because they had their radio turned up. For me though I would park it if you have another option.
Top off the oil and the grease, drive it to NC. It will be fine. People that aren't on Ih8mud drive years on leaking birfs.
^^This. Just keep checking it. These trucks can drive out of some very remote places with far more carnage.
Talk radio at a reasonable volume for the win! If I had another option, I'd definitely take it but unfortunately I don't.
I drove from California to Kentucky with a front axle that looked like that. Just top it off. I've seen 80s in the middle east that look much, much worse than that.
Keep check I drove mine daily until I could get parts for the leak. If an axle shaft birf is making noise could just be dry from the wipers leaking down the grease after it mixed with diff lube. Might get lucky there.
Pressure wash it off and check the torque on the knuckle studs and nuts
Check your axle vent before you leave. Making sure that is unplugged CAN reduce the amount of stuff being pushed out, especially on a long trip that will heat up the front diff. Like Ryan said, top off the grease and oil and drive it.
In addition to what others have suggested, I'd lift that front wheel, spin it by hand see how it feels/sounds. Shake it from side to side also to check for wheel bearing play. On the right side of the pic, part of the rubber wiper (most likely) or the metal retainer is sticking out from the side of the knuckle. Not good. I'd spin the wheel to make sure you don't have something catastrophic happening such as a failed birfield or wheel bearings.
Thanks!
very simple fix , just a bad inter seal ,
Since no one asked, I will. Drive it to Asheville, from where? From Cashiers, yeah, go ahead. From Atlanta, you might want to think about it.
If you don't have an overnight puddle, it'll be OK. Top off the grease and differential oil before you go. The weather's on your side with the cold front coming in tomorrow. Cold grease and oil move slower than the stuff in the AZ summer.
Check the ONSC clubhouse. There are members in Asheville.
Original post said 2.5 hr trip?
Yeah, but over there 2.5 hours can be interstate or serious back roads.
You should be OK. Post over in the ONSC clubhouse. You'll get a response pretty quickly.
