Well, &$%#! Need some advice quick.
Just did a 2.5 hr trip myself, same situation, for Thanksgiving. Top it off and drive, but needed a refill.
Depending on how long it's been since any moly lube in the spindle for the Birfield, can't hurt to check that, but you have to pull the wheel to see into the plug to determine. I pumped that full again yesterday, as it tends to wash out with the oil mobiling it from the inner axle, then I filled my diff. Much happier around town right now
Just a quick update: the Cruiser made it up to Asheville just fine. A little funky burnt smell and some fine tendrils of smoke from 2+ hours of interstate driving but no failures. Dropped it off at the local Yota dealership here in town to get it fixed. Talked to the service manager and the actual master tech and both know 80s really well so I feel like I'm in good hands. They gave me a little 4 wheel drive Tacoma loaner to roll around town in. Overall, good stuff and while an axle job isn't cheap, it was on the list of things to do anyway and they're able to put in all OEM so I'm a happy camper.
Thanks for the reassurance and helpful advice, all.
Glad you made it. But don't expect the repair to be something they will do in an 'afternoon' as in your original post.
A 'leak' is one thing....but I'll wager they will find more going on than just that, since you had 'noise' associated with it as well.
When I did my front axle service (new wheel bearings, Brakes, all new seals, checked birfs, etc) it took me about 11 hours to do both sides and get everything all buttoned back up. That was with a full compliment of air tools, my shop and a good understanding of what I was going to do. Albeit just me working on it .
I'm sure 'professionals' could do it faster...but not in an afternoon. You have gear lube mixed with your moly grease, so they will be pulling the birfs to check them and get to the axle seals. They might find issues with your spindle bearings, etc....or everything might be fine. But a full front axle service (if needed and done correctly) will take some time. And I doubt you have only leaking axle seals and wipers.
Yeah, but over there 2.5 hours can be interstate or serious back roads.
Mine has looked like that for about 4 months and I have driven several thousand miles, and wheeled hundreds, without incident, and eventually I will install the kit that has been sitting here for about 10 weeks. Oh, I did top up the moly once.
Absolutely.
I wouldn't be afraid to drive one that is just 'leaking'. As long as your wheel bearings aren't loose or knuckle/king-pin bearings, then there really isn't much that can happen the to outer ends of the axle that would prevent someone from driving it.
That's one of the things I love about the 80 series. They are definitely over-built and not especially hard to work on.
Glad you're getting it taken care of. I can't imagine that's inexpensive.
Mine has looked like that since I picked it up in March 2016. That was 36k miles or so ago. I purchased a kit from Cruiser Outfitters before I even bought the rig! One of these days I will get around to doing it.
Fun fact, I was cleaning out and sorting new parts I have in my garage. I found two new OEM Oil Seals. The packing has a date Sharpied on it. 4/01. I’m guessing I picked these up for my leaking 92 at some point. But never did anything with it until Nov 2009 when I did my 1992.
Check fluids. Check grease. Drive.
