TIL this is just Bob’s way of saying “Butt”, and not, as I had assumed, bob’s special way of poking the pig.Are we also doing Buttand
welds?
Metallurgist is only going to do what you ask. What do you want from such an evaluation?Are we evaluating the coupons (cutting in half) or sending to metallurgist![]()
My thoughts were to see if we could all try different, size wire, volts and wire speed and find that sweet spot that had a good balance between penetration, weld porosity and burn through on Toyota gauge sheet metal.Metallurgist is only going to do what you ask. What do you want from such an evaluation?
I just can't see SMAW on thin sheet metal like 18 ga minus.
75/25... The biggest bottle you can afford is always the answer..Should I go straight C02, Argon, or 75/25? Will a small 20cf bottle last a little while or am I going to blow through it fast?
Working on getting my welder setup for pig work, I have it loaded with .025 wire at the moment. The last piece of the puzzle I need is a bottle. Should I go straight C02, Argon, or 75/25? Will a small 20cf bottle last a little while or am I going to blow through it fast?
@Ry24000 literally said, “I just can't see SMAW on thin sheet metal like 18 ga minus.”, which is why I responded (to that), with 6013.6013 is Stick welding which does'nt apply unless you are welding structural like a frame.
Or able to lift out of your truck, yes it's come to that.The biggest bottle you can afford is always the answer..
tell the young ‘uns you don’t need help (until you do).Or able to lift out of your truck, yes it's come to that.![]()
My suppliers don't care. I have exchanged nitrogen, c02, and helium for argon and C25. They have a deposit price based on size. I upgraded sizes by getting smaller bottles from auctions or classified ads and trading up. Of course your mileage may vary. Doesn't hurt to ask.So they don’t care if I bring them a green oxygen bottle?
