welding nut danger?
Rio Rancho, NM
How dangerous is welding a nut on transfer case fill plug?
I'm pretty low on gas and it's not to darn far from tank...
Be sure to shoot video, just in case... ;)
I'd say have a garden hose handy, and a full CO2 fire extinguisher. The gas tank is on the other side of the t-case.
I'd use Mig, and a big enough nut you could weld the inside. Ground to the T-case only, and maybe disconnect the battery positive just in case.
I always thought you should weld with a full tank, that way the fuel acts as a heat sump and the vapors don't explode.
I am not a welder and couldn't draw a bead if your life depended on it.
Getting more gas at this point is not an option or I would, I'm dead in the water until I can get this dam thing off. I've tried the chisel method and the nuts so soft it just peels but doesn't turn
I was thinking of just welding a socket to it and then trying to turn it out .
Which would be better a socket or nut?
I welded a 1/2" nut on my front diff fill plug that was damaged and froze. First I welded to inside of the nut the best I could in short bursts, then I was able to unscrew the fill plug very easily. The heat from the welder will help lossen the plug. Then I took the plug out and finished welding it. Have a garden hose ready and weld a little at a time. Maybe do some cleaning first so that there is less grease.
Have you tried cleaning the plug thoroughly, filing the top bare, cleaning an Allen bit, hammering it into the hole and putting a heavy tack on a few sides?
Pull the rear drive shaft, remove the rear extension housing (8 bolts i think) and I think the drain plug comes with it. If not, you may have to take the next section off. It's not all that hard, and it gives you an excuse to install marlin gears... really though, I would just dismantle the t case until you get the part with the drain plug off. Then you should just be able to turn it out from the inside. It comes apart really easy.
if that is 18mm, I have a time sert kit that you can put repair piece into that.
Basically, drill it out, then use this kit.
here is the late Bobby Long teaching about it.
my thread and search for options on the 40 forum
Transfer case plug thread issue - what options?
Great idea, don't forget to have some red FIPG ready to put it together.... wait... I thought the fill plug was on the front portion...
Thanks guys welder was pretty nervous about the aluminum and so I filled it through the speedo cable...easy bolt to turn and 1/100th of the time already spent on that stupid bolt but I may take it apart as suggested next time and inspect the interior, when I don't need to drive for a while. My PM has always turned into "SORRY honey can't drive the cruiser for a few days"
If you really want to get it out you could drill and tap it for a large left hand thread bolt and reaf a left hand thread bolt down into the hole and try to get it out. Or center punch it, drill it out until not much is left around the outsides and use a cold chisel to collapse the sides in until it falls out.
If can't smell the gasoline in the air around your car, you're safe. No vapors, no boom.
But, just as mentioned above, have it on camera anyway. A million hits on youtube would be respectable.
