Weird window problem (possessed??)
Orlando, FL & Southampton, NY
OK, years ago I replaced my original master window switch with one from the Switch Doctor.
Cleaned window switch (question within)
I did this mainly because the original (for whatever reason) lacked manual down and was either Auto Down or nothing at all :hmm:
If I wanted to put it down half way, I had to hit the button down and pull it back up to stop it :doh:
The SD switch fixed that issue and it worked well until the next year when I noticed some pausing going up :oops:
SD replaced it with another switch no questions asked :smokin:
Fast forward to a couple weeks ago....
I noticed one day that the driver window would not go down without waiting for about 5-10 seconds :oops:
It happened a few times on occasion, but soon got to the point where I had to wait or bang on the door a few times in order to go down :confused:
Long out of warranty from SD, I decided to order another el cheapo switch from FleaBay.
$16.35 shipped, I figured why not :meh:
Slapped it in last week and all seemed to work fine :)
Then earlier today, it paused for a few seconds before going down (same symptom of my old switch starting to go bad) :hmm:
Didn't think much of it and since it was such a beautiful day, I drove with the windows down :cool:
Cruised for a bit with my arm hanging out the side, then I noticed the window suddenly get a jolt and pop up about 1/4 inch all by itself :confused:
About 20 seconds later, it went up another 1/4 inch, then another randomly as I drove :censor:
Stopped off at Panera to pick up some lunch for my niece and left the window down.
By the time the food was ready, the window went up almost half way by itself :eek:
Took the switch out, checked all the wiring and pins, then plugged it back in, but it would still randomly bump itself up a little bit at a time :bang:
What's worse is that I can sometimes hear the motor go up for a split second even when the glass is already up :mad:
Now I'm thinking this is might be an issue with the window module or sumthin and the constant going up might be causing the breaker to overheat, which may have been the real culprit of the last switch failing to go down when I wanted it to :hmm:
Anyone here ever run into this problem?
My next step will be tearing into the door and checking the harness on the module, but I'm open to any other suggestions :meh:
I wish I had more to contribute, but this is the first instances I've seen of someone apart from myself having master switch issues. We have replaced ours in every Toyota we've ever owned - Corolla, Land Cruiser, and Prius. Why? Do you ever hear clicking coming from the actual switch itself?
The breaker is heating up and opening, cooling and closing again, this indicates the switch or relay module is stuck in the 'up' position. The normal mode, is the window rubbers start to age and harden, the contacts start to burn up. The switch gets replaced but not the window rubbers, and the new switch 'suffers' for awhile until the problem repeats itself. Other things disguise this pattern, cold weather makes it even harder for the window to raise or lower, it gets warm and the window rubbers soften but it is often too late as the switch damage is done.
Not saying this is your problem, but have seen it many times so worth the heads up in the absence of other replies.
regards
Dave
Sounds like the contacts in your flea bay switch are making contact when they shouldn't. You may be able to carefully pry the button off and get a look at them. Probably worth just sending it back for a replacement.
For what it's worth I replaced all 4 of mine with the switch Doctor units, haven't had any problems.
Took the old SD switch apart just to see what made it tick.
Looked simple enough, so I took the FleaBay switch apart as well and found a few differences....
As far as I could tell, nothing seemed out of place, so I put it back together and it had the same problem for a few minutes, but hasn't happened since earlier in the day :hmm:
@dave2000 thoughts on a breaker heating up sounds plausible, if you could locate that to replace, observe, or short it momentarily to troubleshoot you might at least rule it out. I don't have the EWD handy but Ill try yo take a look for you. Most window systems look for an increase in current to indicate the window is in the up or down position, maybe this is the circuit that is giving you intermittent power. I don't think this circuit is on the switch like the "auto up" is, there is also window control module somewhere.
Just a little update....
Both the Switch Doctor and the EBay switches have the same issue with the window just randomly inching it's way up a little at a time :doh:
I wanted to try my original switch, but it's sitting in my tool box back in Orlando :meh:
Made an offer for a used LX switch on Ebay for $20 bucks and they agreed.
I had planned on pulling the door panel yesterday to checkout the module, but right when I was about to, the mail man showed up with the LX switch, so I popped it in and so far it's working as it should :clap:
Since installing the OEM switch, the problem is long gone :cool:
And I was actually right about the switch being from a Corolla lol
EBay seller admitted to goofing up and offered to send a return slip, but no harm, no foul, so I just said I'll keep it.
Now I'm curious, what other parts OEM are interchangeable between the Toyo lineup :hmm:
Is there a thread or listing showing what parts are compatible?
Would be some good info to have on hand when searching through the bone yards
