As far as inclines and angles, you get out of it what you put into it. As I have said about virtually every part of the powertrain, the fsm is a handy reference point; it is not the Bible. None of my rigs run factory specs. And none of them are duplicate alternative specs. In each case the final settings have been done ON THE TRAIL, where I can duplicate the issue that I want to adjust for.Do the OEM carbs handle inclines and angles easier than aftermarket carbs? Or do we need FI to get all angle/no flood?
The Webers are really too high performance for the tractor motor. I have the 38/38 electric choke and (especially with the valves adjusted) it screams down the road, starts good, idles fine, NO rich/ NO lean... BUT I really want that progressive throttle of the OEM or smaller carb when I am trying to crawl over stuff. I do have experience working in a carb shop out of high school back in 86, so I think I have it well dialled now.
I would love a full OEM setup, but that comes after several other projects.
The only compromise that I haven’t overcome is that adjusting fuel level low enough in the bowl to completely eliminate erratic idle in bouncy hill climbs causes temporary fuel starvation on hard acceleration on the highway.
