Hello!
I am working on a truck with a weber 38 with electric choke. The problem is, I am not exactly sure how it works when functioning properly.
When I first got the truck, the choke was closed all of the time and the choke was not receiving 12V (blown fuse).
It is now wired to a switched power source and I adjusted the choke (rotated the white plastic piece and set the high idle) so that it works great both cold and warm.
I pump the gas once to set the choke and now the truck starts and runs good when cold, and the high idle works fine. The problem is that the moment I hit the accelerator after it is running the truck will return to low idle - which is not ideal when it is cold.
What exactly does the electric part of the choke DO? Seems to me that there is some sort of bi-metal spring in there that controls the choke flapper itself.
What controls the high idle and is there an adjustment for how long the high idle stays engaged?
Thanks,
Andy
Thanks,
Andy
