Weatherstrip Reusable?
Beaverton, Oregon
I'm just about to get my 40 moving under its own power for the first time in 25 years. The hardtop on it was a replacement for the original top that got hit by a tree, and has never been bolted on. I have a box full of OEM weatherstripping and packing strips to seal it down (came with the truck - score!).
Long-term plans for the truck include a full rehab of the top, new headliner, along with some cleaning up of the top edge of the tub. I need to bolt the top on in the short-term to get this thing on the road.
Should I save the OEM rubber for after the rehab of the top? Would it be fine to put it in now, run it for a few months and pull it all apart in the spring to fix things up, then re-use it all again once done? Not sure how re-usable all this stuff is.
I would guess it depends a little how I attach the weatherstripping and packing strips to the top/tub. Can I just lay them in place and bolt the top on? Do I need to adhere them to the top/tub somehow that might make them difficult to re-use?
You can bolt everything together without adhesive, you just have to hold your mouth right:D. On my last mock up I did cheat and used a few dabs of adhesive. Either way works.
Why not fix the top now while it's off, then there is no problem?
Would love to, but the truck has been sitting for 25 years, and I've been working for a year and a half to get it driving again. I'm literally 30 minutes from pulling it out of the garage for the first time. I'm too excited to push off driving it a bit before the weather gets too crappy and cold. :bounce:
I also don't have anywhere else to keep the truck with the top off, and if it's in the garage, I don't have room to rehab the top properly. My hope was to be able to get the truck going sooner and have time to button up the top while the truck sat out in the sun of early fall. Missed it by a week.
I'm in a similar boat. My truck is in good shape but I'm thinking down the road (10-15 years) I might want to do a full up frame off restoration when I have more time and money.
My rig was externally painted about 12 years ago (PO) and I'm thinking I'll need more than the touch ups I'm currently doing. I had pulled off older crappy weatherstripping and am about to put on new OEM rubber.
Not to hijack but I say yes put yours on and drive it! I missed the good weather and can't wait to get the top and such back on and back to driving. I'm not planning on tacking down the hardtop or side rubber just laying it down and aligning it carefully. I think any of the top rubber can be reused no problem. I'm just skeptical of the door rubber that might not be a round in 10 years..
The only hardtop weatherstripping that might require some adhesive is the top cap weatherstripping to the sides. I wouldn’t hesitate to run it without adhesive. The adhesive really just helps it hold in place while you bolt it together.
The door molding isn't available now for the '74, so no worries there. Most of the stuff I don't have is being made now by CityRacer, so if I needed to replace anything later, I'd probably be able to. I'm just going to run what I have and figure later out later. Thanks for the advice!
First drive, by the way, was great. Took my 9-year-old daughter around the block, then up to the gas station. I have a few things to take care of in the very near future, but that was easily the most fun trip to the gas station I've had in a while.
