- Thread starter
- #81
Bump stops are over rated.
I'm sure they are, in your monster truck
You are obviously better prepared than I am. I don't expect to be done for weeks. You need kids to slow you down a little.
... You may want to add a leaf to stiffen them up.
quit your whinning
Did you get your toybox bolted together last night?
Don't give the pipe cutter back yet, you can shorten your rear driveshaft that way and you get a nice clean cut to keep things lined up.![]()
I'm not whining. I wouldn't have it any other way. Brenden know what I'm talking about.
. this gonna make for an interesting skidplate/crossmember Thanks Tim
wow... I'll be 10" longer. this gonna make for an interesting skidplate/crossmember
I'm sure they are, in your monster truckwhats your mesurment to the frame in that thing? 62"?
Frame to the ground or frame to the axle?
I'll have to measure it.
frame to ground
. Thats about four hours of cutting and grinding and resetting everything that I don't want to waste. my other thought is to just cut some .5" plate and weld it to the drivers side plate.
so tonight I'm bummed.
Set the pinion angle, welded the drivers perch in and found out the perch is a good half inch taller. Right know i really want to cut it out and get Dan to send me the right perch. Thats about four hours of cutting and grinding and resetting everything that I don't want to waste. my other thought is to just cut some .5" plate and weld it to the drivers side plate.
