Water temp question
in the stacks
Hi All,
I've searched this forum and others but have found nothing...maybe i'm not searching the right keywords, but anyway, I'm going to ask my question of the fine folks here in the international section.
This evening I plan to install a mech water temp gauge in my LJ. I had thought about putting the sensor in place of the stock sensor, but am hesitating for two reasons:
1) it would be nice to have a backup - two gauges monitoring the temp.
2) the location of the stock sensor is high on the engine, so if the coolant level drops below the sensor, it won't read (i.e. the engine is hot due to no coolant but the gauge reads cool).
Is this second concern a valid one, or am I worrying too much about this? Is there any good reason to look for a spot lower on the engine to install the gauge?
Finally, what is a the normal temperature range of coolant at operating temp? I've never had a gauge with actual numbers on it, so I don't know what the danger zone would be...
Robin
210F is boiling...
i install them at the other bung on the thermostate housing and run both just like you mentioned...
cheers
for the last question......
If your thermostat is an 88 degree, normal will be over that, maybe 90-95.
My Ford has the numbers...red is 125. I think that is pretty common.
Normal is at least 5-10 over the thermostat opening. Otherwise the thermostat would open and closing all the time and it would be toast in a short time.
The fan and the rad provide the optimum cooling, not the thermostat IMOP. I could be wrong. But I think that is the way it is.
I am gonna guess normal is around 90 for you. maybe 95. With the thermostat closing with anything less than 88. To keep the engine at its happy warmness :)
crushers said:
210F is boiling...
cheers
Only if its water only. Antifrezze raises the boiling temp considerably. Well above 100 celcious(210).
http://www.eetcorp.com/antifreeze/antifreeze-faq.htm
"Antifreeze (engine coolant) performs several functions in addition to providing freeze protection. Antifreeze contains chemicals that inhibit corrosion and scale formation in the engine and radiator. Antifreeze (engine coolant) provides protection against boiling in the summer. At one atmosphere pressure pure water boils at 212 °F (100 °C) but a 50/50 blend of water/ethylene glycol boils at 223 °F (106 °C). "
Taken from that website.
Strange you write this...
I have a mec Temperature sensor and when I look at the gage I see it move (not always... but severale time in driving city) to 190 (88C) to 160... then going up to 190 then going back to 160. I figure it move down when the thermostate open at 88C and it chill the fluid, then close... then the fluid get hot again... then open again... see the patern ?
I think that normal because it cold outside....
but your post make me feel not so sure now...
Any opinion ? Someone think it not normal ?
Oh I think you are describing normal......BUT not right. Since our 3b's don't make a lot of heat they need to have the rad covered in the colder weather. Otherwise you will get this cycle all the time.
When was the last time the thermostat was changed. It could be sticky too. Or just the opening of the thermostate lets the cold antifreeze in and it drops too much, then the thermostat closes again till 88..
Block your rad to see if the visious cycle can end. You best fuel mileage is gonna come when you can be stable with the tempoeratures. Cold engines burn more fuel.
The problem in the cold with a diesel is the dam thing cools down when we idle. Not warm up. SO we need to cover that rad.
I seen a guy, when I lived in Ontario(northern) that had a diesel VW, he had every area around the engine filled and blocked with pink insulation. To help retain some heat. Kinda looked silly, but this was an early 80ès VW. So maybe it was a big help.
OK. Nice.
I realise it was burning more fuel than normal. I know that's the way on gas engine (very cold temp = less L/Km) put I alway what to know on diesel but never ask the question... (who know why ? :rolleyes: ).
That make sense.
... I will covered it.
Thank
PS: Sorry for the highjack
crushers said:
210F is boiling...
cheers
Other bung? Hmmm...well I installed it in what I believe was the stock sensor's spot (the one that's directly under the top rad hose, kind of pointing at the front left corner of the truck. My wiring diagram said yellow/grn, and that's what this was, so I pulled it) There is another sensor-looking thing on the housing, which faces the front of the vehicle, with two wires coming out of it...is that the "other bung" you're referring to, Wayne? Or are you talking about drilling and tapping at another spot? I'm thinking of installing a "T" fitting so I can run both gauges.
All in all, the install went pretty smooth, but the relatively short capillary tube on the gauge meant that I had to run it along the back of the firewall, pretty close to the turbo and then up over the valve cover. I ran it as much as possible behind the fire-retardant stuff that covers the firewall, but I'll need to put some kind of heat shield at a couple of spots.
Anyway, thanks for your help everyone.
Robin
Tapage said:
I thought all Toyota ( old ) thermostats are 82ºC .. 2H, 12H-T, 2F, 3F etc ...
very possible. Can someone post the different part numbers and settings.
I saw on here once someone posted the number for the 88.
90916-03103
A thermometer requires that it's transmitting probe have a flow of circulation around it to give a precise reading.
It is the reason why one T cannot be used because it does not have circulation around the probe.
HTH
And here a little physical principe :
If the pressure exerted on the liquid increases, the boiling point makes in the same way, and conversely. Thus, each fluid will be characterized by a curve of change of state: the relation pression/temperature.
So in the engine, when it get pressurized, the boiling point (water/anti-freeze) is not 106C... but over. I don't know the Temp. but if you want to figure by another exemple : if you have a "presto" (kind of presurized cooking cauldron) in your kitchen, keep in mind the cauldron make the water boiling at 121C because it have 15PSI.... that why potatoes cook so fast in that kind of cauldron....
.....but that not Landcruiser anymore now ! ;)
the atmospheric press afect this point .. ( boiling point ) .. ? without htinking in the most of cases when you have more than 1BAR you have less Oxigen .. for altitude .. and you enviroment are more fresh ..
I am misunderstanding.......
if you climb a mountaint and boil some water. Stick a thermometer in it and the temp will be lower than 100 degrees C. where as at sea level it should be around 100. Lower than sea level, higher....
So in New Orleans it takes 104 C to boil water, LOL.....or the dead sea.
my error .. I underestand right now.
Sending unit thread types
Robin
I am ready to install a Water Temp Gauge on my 3B - I was wondering what is the thread type of the original sender BSTP vs NPT? :confused:
I also see two ports on the T-stat housing one has a long probe and two wires coming off the connector, the other which is located right next to this one is a shorter probe maybe 3/8", vs 1", and has just 1 wire coming off of the connector. (what is this one for?) :hhmm:
I removed both and measured thread dimensions on the longer one - .465" outer diameter, with a thread count of about 18threads per inch (this is a rough estimate).
The temp sender of this gauge fits only in the port that had the longer probe, but this means I lose the Toyota factory temp gauge - bummer:doh:, I was hoping to have a dual system. Or is there another way to get both systems working side by side?
Thanks for any help!
-RYan
-RYan
I installed my mechanical gauge to an unused fitting the in the head (not the T-stat housing). You'll see a square (4-pt) plug on the right side of the head behind the tstat housing. Its 1/2" BSPT, which is interchangable with 1/2" NPT, and the hole is very deep, there is 2 or 3" clearance for looong probes.
Details of the location, as well as of the thread issue are here:
https://forum.ih8mud.com/diesel-tech-24-volts-systems/272419-urgent-irritating-bspt-problem.html
Awesome! I found the plug, just need the right tool to get it out :) my power steering pump bracket frames it nicely- though a square socket I don't have.
And getting the sensor in there with the wires attached ought to be joyful.
I am glad I am not a surgeon, for my patients would end up with scars and strange behaviors if I treated them as I treat my Lancruiser...
