Water temp question
I also see two ports on the T-stat housing one has a long probe and two wires coming off the connector, the other which is located right next to this one is a shorter probe maybe 3/8", vs 1", and has just 1 wire coming off of the connector. (what is this one for?) :hhmm:
The one w/one wire is the water temp sensor for the gage
The one w/2 wire is the water temp sensor for the glow system (ST-6 in the 3B FSM)
I don't remember the exact thread partern but there a couple of adaptors in each mech temp gage kit and I found the good size in the package... anyway, I think amaurer is right.
This is my set-up :
HTH
Amaurer - I will check sears for the socket, good tip!
David - the location of your mech. temp gauge is different than what Amaurer suggested above. Any idea if the two locations produce the same results?
No. The results will be the same. I see just a difference ... is the needles of my gage drop a little bit (one or two time) in the first km because it is located next to the thermostat. (when it open)
The hole that amaurer is proposed is useless on my BJ70 because the function of this hole is to send the coolant to the rear heater.
The coolant hose for the heater is different between BJ70 and BJ42... I think this hole is available in your BJ60.
let us know.
Sorry for quoting myself ;)
I thought about that ...
Although ultimately, the results should be the same... the amaurer's location take the temperature directly INTO the engine head, as my location is reading INTO "the pipeline" ! (But still under the T-stat)
In fact ... no ... there should not be any difference. unless someone has a different opinion ... ?
