So the 97 Cruiser is finally back from the suspension shop and I have been putting miles on it. Went to use the heat for the first time in a while and got nothing. Was running the ScanGauge while driving and seeing temps fluctuate a lot more than normal. Truck is usually 186*-195*F all day with AC running. Now I'm seeing 200*-216*-220*F and no heat.
I'm just running distilled water and have been all summer as I dump and swap it out every 4 weeks or so in an effort to clean out the brown sludge from the PO. Swapped new water in, no change. Swapped in a new thermostat and changed water and all was good. Took it out this AM and it went to 216*F on the highway and no heat. Let it sit for 90 mins and then it runs at 204*F no heat, then all of a sudden 190*F and full heat. It ran 190*F all the way home (10 miles) on the highway.
Concerns are that I'm seeing what looks like a latte color in my catch can, but the oil seems fine. Temps are all over the place, but no overheating. It is running an intermittent P0306 code as well. Not sure if that is related. Bottom line question is ... does this seem like a water pump issue? The pump has a slight "chirp" to it at idle as well. Looking for some guidance before starting to tear it down.
This is what I'm seeing in the catch can. Possible the water up top is boiling off and causing the froth?
