water pump ish?
Eagle, ID
I was driving my 40 on sunday when it started to overheat. It steamed up and lost almost all the coolant 150 yards from my house. I turned it off and cooled it off (it was 20 degrees outside ) and made it home.
I could tell the coolant was coming from the water pump so i pulled the front bib, radioator and water pump. this is was my first time doing this so i took it all out to have the radiator boiled out.
once getting the pump out i was looking for where the coolant was coming from and it is from a hole on the bottom.
I woke up this morning to order a new one from spector after doing some research and i see this same whole on the one i am ordering from spector. what gives? what is this hole? do i not need a new pump? my pump seems to have some play in the pully so i figured i needed one even with the wierd whole.
spector link: http://www.sor.com/sor/partpict.tam...x=1&descriptionpg.ctx=Page 054 Cooling System
any input would be greatly appreiceted.
little background. This vehicle has sat for about 6 years. I drove this vehicle in high school as did other siblings. i recently bought it from my dad and have been doing ome lift, tires, new (old) rims and hub caps, power steering ect. I figured i would have problems like this so i have been daily driving it to hopefully have them come up if they are going too.....
A coolant flush had not been done yet and the coolant was pure rust water crap. I had actually bought some fittings to do it but had not done it yet...
I can't tell you what the hole is, but it's my understanding that once there's play in the pulley like you say you have, that the bearings in there are on their way out and it's time to get a new one. I used to have a van that I put a new water pump in, and when I pulled it out it had play in it that I was told was not supposed to be there...
The hole is supposed to be there, its on all water pumps. When water starts puking out of the hole you know the pump is bad.
The reason it pukes is that the bearing and seal have given it up. Boiling the radiator is a good idea. If you put a flush kit on it, I would bypass the heater core because what you dislodge in the cooling system can become stuck in the small passages of the heater core.
Just put a new pump on it and use new coolant. The "antifreeze" portion of coolant does not necessarily go bad, but the anti corrosion/rust properties do go bad with time.
GL
Ed
thanks... I figured it was for something like that but this makes way more sense than what i thought. thanks for the input. I feel alot better about spending the 150 bucks now.
Bret said:
I Believe it is called a "weep hole" A.K.A :my water pump is about to crap out hole". generally starts to leak a little before catastrophic failure
Yeah thats the name of it weep hole. Another way to check your water pump is to grab the fan and apply pressure up and down ("wiggle it just a little bit"). movement or clunking will let you know that the pump shaft bearing is going bad. Common causes I have seen that contribute to pump failure are old coolant with high solids and running the alt. belt too tight. I check mine for movement during oil changes.
GL
Ed
I learn something new every day. This is a great idea. Could you reverse the flow to take care of this happening?
Depends on the year for OEM availability. Mine s*** out 2 weeks ago. Engine is a '77 without oil cooler. A few years are discontinued through Toyota and the '77 just happens to be one of them. I called CDan and unfortunately he couldn't help with mine. My Beck/Arnley replacement arrived today, it even has new pulley studs!
Need a 77 also
Hey green73,
I'm in the same boat as you. Need a new water pump for a 12/76. I'm trying to decide between CCOT, SOR, etc. Where did you end up buying yours from? May I ask how much?
Are you replacing the fan clutch? I've been considering the pump/pulley/clutch combo that CCOT has.
Thanks,
Sean.
sbaker, there is a reply to your PM.
SUCCESS!!! Don't mean to hijack the thread, but Advance Auto came through! My engine is a late 76 early 77 model. found the water pump at Advance Auto. It is a Beck/Arnley new pump. Part number: 131-1547. It has the boss for the factory oil cooler, so it looks a little different than stock. The boss is NOT plumbed for the oil cooler though. Price was $100. Hope this helps anyone in search for this vintage water pump.
Do you have a fan clutch on your pump set up that was in your truck, and this pump is compatable with it?
Yes the fan clutch would have worked. The pulley went on with no hassle, and the studs are long enough for the fan clutch flange. Same dimensions as the factory piece as far as the snout goes. I am running an electric pusher fan though. Yeah I know the factory fan is very sufficient, but I broke it and the radiator in a flop, and went electric after that.
