I have a 1990 4Runner with the 3.0 V-6, I noticed the truck leaking water, this is a pic from the under side, it's leaking from the drivers side were the lower radiator hose goes in(I believe right were the thermostat is) The truck does not leak much water until the truck is turned off, then is starts leaking, I've heard this could be a water pump issue, is the water pump directly behind the fan, would it leak out the drivers side if the water pump was bad, could it be a gasket, is it like the 4 banger were the front is a separte piece? Thanks for any help, just wanting to know were to start! Jason
Ok, 1st thing you should know is that all water pumps have "weapholes" a small hole out side the seal's from the propelar its usualy the first thing to go so if you get to that point your on your way to a W.P replacement
you must asertain if its the weap hole first, so as not to change the part that has nothing to do with the problem...........bad thing is the 3.0 desighn is not friendly to common maintanince W.P, T.B, tensionar, (cam)Timing,..................but I think thats enough for now.
2nd, cold water contracts and hot water expands, also the could water is not flowing (T.stat is closed) hot water is flowing and has expanded.
3rd, I do hope you have another form of transportation, while you (or ?) fix it. It does not take a lot to overheat this motor.
4th, IMO, get a Toyota W.P, front main (oil) seal, and Timming belt they are the best parts to use.
5th, it is nothing like the 4banger, the timing belt runs the waterpump, and the T.B is behind all the stuff you see when you open the hood.
Dont be discouraged you are not the first to have this problem.
Please get a service manuel. look
here.
Idea, call C-Dan ?
