Water in Rocker Panels & Passenger Floor from Sunroof?
Canada
Hey Everyone,
I have recently noticed a significant amount of water accumulating in the frame of my 2005 LC. At first I wasn't sure where but my mechanic said the water (literally gallons) was in the rocker panels and he was able to drain it by pulling a plastic plug on the passenger side. I saw some water under the carpet and am drying it but the pulled plug seems to be keeping the water out.
He and I think it is the sunroof drains somehow being plugged up but I can not find a drain tube on the underside of the car at all. Does anyone know where the sunroof drains are supposed to drain to? Any chance someone could post an image identifying where I should be cleaning out debris etc or where they might be located. I've looked around and can't identify anything that would appear to do this. Thanks in advance!!!
I've got the same problem. Just ordered a sunroof seal to fix the initial leak. Compressed air works best for clearing out the sunroof drains.
weed eater string works well
JerryB - big big thank you for this. I cleared out all my drains, that are located the length of the rocker panel, based on your photo.
