Washer mod for caster correction
Lakewood, Ohio
Are there any how to threads on the washer mod? I get the concept but I'm not clear on how to measure caster (castor?) also @Photoman's adjustable approach which satisfies my reluctance to commit to anything, ha ha. I really want to avoid the correction bushings.
Anyhow I was searching long and hard for a how to on the subject and it seems there was one on an old Aussie site which is no longer up.
I'm looking at 2.5" OME heavies front and rear.
I keep reading so many complaints about the bushings though...
I agree when I remove mine the sleeves just fell out.
A little more lift and caster plates would be perfect.
Most common complaint I have read is that they are not ad aquatic after going from a 2.5 lift to a 4-5" lift. Many of them are Poly, which can give a firmer ride, but if you want a stock ride then leave it stock.
The old "cut and paste" trick with the steel hot glue gun.
7mm per degree, enough room to go 14mm but I go 12mm normally, as you can see leaves the right space for the washer to go welded on. So slotting the front housing holes down for diff to tilt upward, changing king in angle for more caster.
And bushes for 3" lift at 2 degree.
I also like to go this way for some neg camber as well.
I originally found the info on the Aussie site as well. Not sure where the site is now.
Here's a link that might help: Washer Caster Mod
I have done this on several 80's with 2 1/2" lifts with new OEM bushings and all is good.
The caster will be wrong for that lift with just "washer mod"
The bearings you can do up to 3 deg so .5 for camber and the rest caster.
Simply for the sake of clarification, are you saying that moving the bolt down 12 mm will not be sufficient for correction?
Hmmm...... I think I know the guy that wrote that article?
Find other mod write ups on the linked site above;) Sponsored by Copper States Cruisers
Not on its own for even a 2" lift.
For the normal family wagon we add around 20 minutes neg camber, I run 40-45 minutes on my own vehicles with larger tyres.
Its where the heavier rear sway bar kicks in, because the car becomes pointy, turns in better, it can induce more roll steer in the rear, trying to keep up.
Thanks for the reply...unfortunately I'm still confused.
For a 2.5" lift I need to move the washer down 7mm/ inch of lift, so ~17.5mm.
is the camber bearing necessary or is it an alternative approach?
What do you mean by minutes?
Came in thread expecting sweet washer fluid or pump or sprayer nozzle mod. Was disappointed.
Minutes being fractions of a degree. 60 minutes to a degree, 60 seconds to a minute.
So 20 minutes would be 1/3 of a degree.
I have the 2.5" OME mediums. I dropped the hole just over 1/2 inch.... welded up and it was much better. On the alignment machine caster is out but I have no abnormal tire wear and the truck drives fine. it does not wander or have to be fought. I just installed the MAF 30mm spacers up front without ill affect.
Sounds like I need to brush up on my terminology :hillbilly:
When you become a long term committed Cruisernerd, you will be wise to the ways of the long term wordsmithery !
