Washer mod for caster correction
I just wanted to chime in that, if you don't like the poly bushings, I used the TJM rubber offset bushings for my 2.5" OME lift and they worked great. Truck handles and tracks fine. AND they were about $60 shipped.
Put 3 degree bushings and get it over with. The bushings likely need to be replaced anyway.
Mr. @Tools R Us , for one that has been pro washer mod for many years & have posts on doing it. It just seems odd that you just write just put in 3° bushings...
Tire Lowering on Rich's '80
HAAANK is right, it is not easy to find a specific How To do a Washer Mod thread out there. Most that is documented are hidden in other titled threads. I believe the Landtank plates are the same thing & are well documented, but not the Old School Washer Mod. Will a 80 veteran as yourself post it up with pics for historical purpose.
Also just lowering the front bolt will create tie rod hitting/binding issue. I have read one needs to roll per say the rear bolt also. In the link above mentions 3/8"th of an inch.
Again I'm no expert on this & still up in the air with what I'm doing with my front end. Im currently over corrected with MAF brackets & blown out 2° OME yellows.
I have in hand 4 new stock bushings, I also have the 8mm adjustable rear arm Super Pro blue bushings, but still debating if I want to push forward the axle any.
Hi,
I know this is an older thread AND that it should be pretty self explanatory, but it turns out I am an idiot, so don't get it. I read this thread and every other thread I could find as well as the two that are linked, but I am still not clear on the 2 degrees of castor or more specifically how to get it.
So, the Washer mod includes relocating both front and rear bolt holes? If yes, then the rear hole is repositioned "rear holes in the bracket ~1/4" back and up ~3/8" and the front moves straight down 12mm?
<Flamesuit ON> so be as mean as need be, just help me understand
We have 4 inch ironman springs with 1 inch spacer in front. I went thru hell getting the stock bushings out by hand. Then put in the blue castor correction bushings and the springs never were straight. Bushings fell apart in about a year. Then I had a shop press in new Oem bushings and did the washer mod. I just rotated the axle until the springs seated straight and welded the washer. Not a problem since. Couldn't be happier. If I had to do it over I would keep the original bushings and just do washer mod.
Oh, and I did not modify the rear holes. I had to slot the front hole all the way out to provide enough adjustment. It may not be perfect, but it works great.
My .02 cents on poly bushings is that they were developed and marketed as "performance" and higher quality by those that couldn't afford the equipment to produce a proper rubber bushing. Compliance is an excellent thing for flex on a cruiser, on a well engineered car it usually means toe in during braking or negative camber on hard corners. Soft and smooth.
Fwiw I still have not executed this mod. Seems almost too simple and I keep thinking that Im missing something. At the end of the day I want to do this right, once, which means I keep putting it off.
This is purely my understanding, and I was wrong once before. It's been a while since I researched the washer mod. And I have never done it myself...
But, I think what is not getting mentioned clearly. Is that you need to slot the front and possibly rear holes on the axle bracket. Loosely reinstall the bolts and some washers. Then rotate the pinion up or down to get the desired angle. Then tack the washers in place, disassemble, weld, and paint, then reassembly. If I remember correctly 2-4 degrees is Toyota spec.
How do folks measure the castor during the process? Degree or angle finder on the pinion maybe? You would need to know your before numbers I guess.
I never checked the castor numbers. I drive the hwy to trails and back with no vibrations or shakes or driveshaft whine, so I save the money and don't have a shop check the castor. It's more important to me that the springs are equal and straight on the perches. I also do diy alignment.
In my reading and in the link I posted above this seems to be pretty accurate and is what I used
"Elongating by bolt diameter (14mm) moves caster two degrees. Four degrees change could be obtained by doing similar elongation to back mounting hole in opposite direction." I dont remember exactly but it was around 1 or 1.5 inches of elongation....I think...several years ago.
If you are using OME heavies you need to do more research. You will be lucky to get 2° and the difference between 2° and 4° is very noticeable.
somehow I missed the heavies. I am on 851/866 on 33's and I am certain that the limit of the washer mod is close. 35's would work but after that more correction and pandoras box seems cracked open for additional steps.
OK,
you slot the whole out front for the "washer mod".
You can slot the rear hole up for more but steering arm clearance to the control arms will be your enemy.
You can press the arms and bend them too, they are forged not cast, so some room can be made and caster gained this way. This and washer mod were the way it was done before offset bushes were available.
You can also grind the "hump" off the radius arms to gain afew mm clearance as well .
Which is why the caster bearings are good for more, no tailshaft vibe or radius arm clearance issues when you rotate the swivel housings only to gain caster and get the advantage of some neg camber too.
And while your under there with the welder, fix the panhard rod mount too, save doing it later, or after its broken off.
standard caster spec is anything from 1-3 degrees. if you can achieve 4 degrees, do it, I set up my 80 with 4 degrees and steering was rock solid.
you can get an approximate measurement of caster by placing an angle finder aligned front to rear across the two bolts of the top kinpin
