warm a/c is so illusive
so my a/c still cuts out on warmer days (and it is getting hotter) and not consistently either
brought it to the local mech and double checked for freon leaks and no dye has been found or is leaking
doing some additional searching I too have the compressor cycling at stop lights sometimes the rpm's are low in the 400's when the compressor cuts out
I have noticed water on the floor so I know freon is circulating
question is can the fan clutch cause both of these problems-compressor cycling and intermittent warm a/c
can the expansion valve be a problem even with water on the floor with the a/c on (even when warm)
can this problem be addressed with gauges even if at the time the problem isn't occuring ie. I have brought it to my local guy twice and each time the a/c was apparently working well
oops yeah "elusive"
and thanks for the evasive answer
search? that's all I do on this site
guess I'll search some more
https://forum.ih8mud.com/showthread.php?t=145955&highlight=a/c
guess I should post my previous thread on this
well the car is not overheating. I have had the radiator, thermostat, all hoses even the phh replaced, coolant recently topped off b/c of a now fixed heater hose leak by the firewall
I am just wondering if it would be a waste of time to have someone look at it when all times all seems to function fine.
If you haven't changed the fan clutch, that would be next on my list.
Compressor cycling on and off while idling may be normal operation. When does AC cut out? sitting in traffic or while driving on the highway? If it cuts out at highway speed, then I don't think a fan clutch will help. If its while you're in traffic, then the fan clutch may help.
when the a/c cuts out it can be either on the surface streets or highway
and once it is out it doesn't come back until the next day
I am thinking something like the a/c cut off switch may be intermittently bad or expansion valve needs to be replaced or the compressor clutch? But can these things be diagnosed when it is working fine? I have already brought it in twice and I feel like I am wasting people's and my time when it just comes back with "all seems fine".
If it quits working for long stretches (a day at a time) then I would suspect an electrical/switch issue somewhere, not the fan clutch. If you're taking it to a shop to have it looked at, why not just leave it with them for a couple days and let them drive it until they duplicate the problem (since it's intermittent in nature).
Not sure of exactly what is happenning with it from your description..... does it cool just fine then seem to just stop cooling? Does it begin to cool after an hour or so or if it sits for a while?
Common issue is crap in the system that freezes and clogs the expansion valve with ice. Ice clogs valve, no ac. Ice melts then good AC until it freezes again.
the last time it happened it was cooling fine for first 20min of a h-way trip then it started to go from cold to cool to warm
but I do remember it just blowing cool to warm, never getting cold during hotter days
I think there was a day the a/c came back after a 2-3 hour rest, but it was already evening and outside was cool
hope this may help to pinpoint something
I guess I could just leave it, it is my daily driver, but at this point I have no confidence in the a/c esp. now that it is getting hotter
The next time the air con stops cooling, turn the fan to max and turn off the compressor until the air blowing out becomes warm. Turn the compressor back on at that point. If it's cool again, you've probably iced up and you now have the tedious problem of finding the cause. Possible causes are dirt in the lines, a need to clean the evaporator, a bad thermostat, or something else I don't know or can't think of at the moment.
The reason for turning the compressor to off is to allow the air from the blower to melt the ice, if it's there. The ice would normally be on the evaporator, the thing that looks like a radiator, and if ice builds up there, cooling disappears.
The business of the compressor turning on and off in a very short time might be caused by a defectively set thermostat. Try turning it to more cool. The day's temperature might be too close to the setting of the thermostat.
Air cons are a job when they don't work to our satisfaction. Good luck.
Kalawang
X2, I had the exact same symptoms, and a new expansion valve fixed it for me....
before my rig started to show signs of cooling system problems, my A/C would start cutting out intermittently.
I'd start looking at the cooling system...
thanks guys
this gives me ideas so that I can give that local mech a clue.
I will have them look and specifically replace the expansion valve. It does seem like it could be the expansion valve.
It blows cold-cool-warm, almost humid like warm, after about 30min to 1 hour of use. The a/c did come back once but it was later in the day and cooler. Also noticed one time after stopping at a store an abnormally large amount of water under the car even though it was blowing warm.
I hope the third time is a charm. I will post an update.
>It blows cold-cool-warm, almost humid like warm, after about 30min to 1 hour >of use.
This sounds like a big chunk of ice forming on the evaporator. The poor man's fix is to simply turn off the AC and turn up the fan when you first start to feel that warm/humid feeling from the vents. This will hold you until you figure out what's really wrong, unless you live in Houston, TX. Be sure the drain hose from the evaporator is clear and that all the water is draining out - you want to get the water out of there as fast as possible.
Some A/C circuits have an mechanism to sense when the evaporator is icing up, and turn off the compressor. Not sure if the FZJ does, but I'd look at all the things that control compressor cycling, including (eventually) the expansion valve. I personally doubt the cooling system of your truck has anything to do with this problem.
FAN CLUTCH. The single most overlooked item in the cooling system with a lifespan of approx 100K miles.
When you say the truck is not showing signs of overheating, are you going by the factory dash gauge or a real gauge? The OEM factory gauge is notoriously insensitive to coolant temperature changes.
The compressor will cut off periodically to bring down coolant temperature. If the coolant temp stays high the compressor will not come back on.
After the AC stops cooling you should check to see if the compressor is engaged. If the compressor is engaged then it's icing up. If it's not then it's being shut down by sensors.
UPDATE:
Got the cruiser back had the expansion valve replaced. Old one was not working causing a vacuum in the system. While they were at it, I had them replace the fan clutch with an OEM clutch.
Well it is blowing stinging cold. Will be taking a long trip over the weekend and we will see if indeed this is the fix.
Thanks again guys for your insight!
edit: Oh Yeah-made a copy of this thread for the mech to read.
