Thanks Johnny. Half debating to literally leave it accessible without having to pull anything out. Then just tuck it back up under
My special "KR" antenna is in, as is the splitter...works like a freakin' charm! Relatively easy to do. I also followed KR's advice on attaching the new cable to old one and pulling it thru. I can only imagine the headache with routing that would have caused...
Thanks again Kevin and Johnny for product and advice!
WTH!
You guys are the ones posting about your antenna mounts, and you are the two guys who are having trouble with the splitter?!?!?
I call false advertising!
Seriously though, great that the mounts are working out and all, but both Johnny and fj are having trouble with the splitter, Johnny's doesn't work and fj's only works on FM.
Anyone else having an issue? Both my AM and FM work fine (went and checked again).
KR
Kevin/Johnny,
I've reconnected my termination from the FireRing to the splitter and no change. FWIW, I also unplugged it completely and was still able to get FM and nothing else. That said, I'm not sure I'm convinced that the splitter is the issue. I'm going to go back over the entire install and try moving some of the pieces around a little and rechecking everything.
Johnny,
Did you try any adjustments on yours? Still not working properly?
. Have the ground installed properly between the mount and the body? I can go look at mine later if you want, but I realized that that portion is the only portion I didn't cover in my install pics.Bumping this thread because I have a question.
I'm not a CB guru and know very little about it. Don't need a CB in the rig either.
Can this setup be used only for FM/AM ?
I really like the look of the long antenna on the 60/62 and need to replace my factory power antenna.
Thanks
Spook, you could run something like this for the quick disconnect, they have a handful of versions.Spook50 Okay yet another OEM antenna mast s*** out on me again (same as the other three I've gone through, the plastic insert broke and it won't retract), so I'm seriously considering this option. Is there an easily removable antenna though, that won't leave the washers and grommet hanging loose when it's removed? I know the 4' would be ideal for using the CB out in the boonies, but I park in parking garages most of the time I go downtown here, plus I don't want to have someone walk by and simply yoink my antenna, lest they get pistol whipped
. Mine has no continuity through the center pin. Did you guys have any luck with Walcott getting a good replacement? I'm gonna give them a call them later today and see if I can get them to test the next one before shipping. Add me to the "got a bad Matchmaker splitter" pile. Mine has no continuity through the center pin. Did you guys have any luck with Walcott getting a good replacement? I'm gonna give them a call them later today and see if I can get them to test the next one before shipping.
Butt
Props to Walcott for standing behind it. They gave me return authroization with no hassle this morning, and commited to testing the next matchmaker before they send it my way.
Butt
I bought the antenna mount through Kevin, and all the other stuff through Walcott.Did you get yours through Kevin or buy it separately?
