VW diesel None cruiser related...
I know a bit here and there but I'm no expert.
I think the 1998.5-2003 Jetta and Golf's are the ALH engine designation. Basically a mechanical injection but computer controlled. They are the engines the hot rodders go for. Very robust and easily modded. They have a rotary, meachanical fuel pump.
I have personally owned two BEW's (2004-2006ish). They have an pump on top of each injector and are commonly referred to a "pump nozzle" or "pumpe deuse" something or other. They have more injection events and there for are quieter and make a bit more power. Because of the higher injection pressure and the more refined spray pattern they suffer mpore from dirty diesel being run through them. Pretty common place really, just make sure it isnt the original fuel filter in there. They also dont bung up the intakes like the ALH's.
Both the above engines benefit from being run hard, or at the very least exercised once and a while. City putters really bung these engines up.
FWIW the two BEW's I have had never went wrong once. 10,000k oil changes and 30,000k fuel filters..... timing belts at 160,000.
They really are a joy to drive, on paper they don't have the most HP but its nice to have a load of groceries, wife, 2 kids and the dog and not even notice it on the hills. No need to shift gears very often as the diesel just chugs along.
Don't know about the autos.... manuals are the easiest, smoothest and most wonderful(est) trans I have ever shifted in a small car. :popcorn:
I talked to Jason and he said he's never done a clutch in one ever.... tends to suggest they are rather over built.
Both of mine have had pulled trailers and never complained about it.
Parts can be expensive so I'd pay a little more for one with a good service history rather than save a couple hundred on one with a questionable history.... but thats just me.
Oh yeah..... the wagons are the dog's bollocks. No matter what other people say. :D
I concur with you Cam on this particular topic and you are the VW guru for sure......
Recently I picked up a 1997 Tacoma which sits in the drive way pretty much all the time, thought I needed a pick up but hate hate the fuel economy of the little 3.4...
I will totally derail this thread and say I far prefer driving my BJ42 over that Tacoma, thinking the Taco has to go...:)
But I absolutely lub my Vdub....
To keep the de-rail going....
Don't like the 3.4? Or the Tac? Gotta say the 5VZE holds a special place in my heart because I had a truck with the 3.0 (3VZE) and wished it were the 3.4 every second of every day.
Funny thing.... When I drove my 60 up to the Yukon I shot up hills at 100kph the same hills I remembered the 3.0 being stuck in third, 80kph, taching out at 4K. Gawd I don't miss the 3.0.
I'd love to get my hands on a 97 3.4l T100 extracab one day. Perfect size ride for me but they really are rare as hen's teeth.
I have a love/hate relationship with my vw. Leaning towards hate. 96 passat.
Mileage is outstanding. 55+mpg , and 60 if it's all highway...it's been a good car really. Only issue I need to fix is a small coolant leak which is incredibly common because those kraut geniuses thought a plastic fitting with an o-ring would be a good way to plumb coolant into the head.
Other than that, it's a comfy car. Drives pretty well, lots of bells and whistles, vile hateful thing to work on.
Imagine the most infuriating tiny confounded knuckle scraping spot to work on in a cruiser, (upper door hinges come to mind...dash side) it'll be better than anything on a vw. Changing an air filter on my car is almost enough to make a guy lose his s*** and bust out a large crowbar and bfh.
And when they DO put something in a somewhat accessible spot, (provided you're triple jointed and your skull has the regulation ninety degree corners necessary for german car ownership) they'll use the most inappropriate fasteners imaginable, or you'll breath on a wiring connection and be left with some random electrical fault.
Or better yet, the temperature will get marginally below freezing and the design of the door latches that doesn't allow water to drain WILL allow them to freeze, meaning you need a supply of bungy chords in your trunk to keep your ******* doors shut.
One one hand, I want to sell it, on the other, if Mel gets a job in nanaimo, it burns exactly 1/2 of the fuel her crv does.:meh:
I was also thinking that if I decided to do something major to the datsun it'd be handy to have a second car....but as the weather improves I always have the mighty ford to fall back on if need be.
Apples and Oranges, guess I do not hate it, way better power than the 3slow I had and better economy... Just kinda sucks in the trails here with that long wheel base and couple feet sticking out the back...
Heard you could get the 2.7 in that year T100, my guess it would be a little bit slow..
2.7 is a gooder. A buddy "in the know" says you can run. 7psi into those engines with no other mods. The over built fueling system just sorts out that air/fuel mixture. More than 7psi though and your fighting the fuel battle.... Pumps, injectors, maf's etc.... The list on my Audi got long and expensive. Never again, but it is fun to create little sonic booms around the neighborhood. :)
Must admit, I had a gasser wagon, looked long and hard for a diesel before I purchase the Golf...
Off topic.,kid drops into the shop with a 1985 extra cab pickup, lil diesel under the bonnet, turns out its a little jetta diesel.... kid built the adapter himself and said the install was quite simple... Running around with lift and 33s averaging 25MPG, 30 MPG highway...
Not shabby..
Not shabby..
Engine cover painted with the rising sun logo? He has a build thread on tdiclub. Does look pretty cool. I'd have hoped for better mileage than that if it was me tho.
Thats the truck...
Cool rig. Nice to hear the VW diesel out performs the other two engines the guy had in it previous.
Funny that Camaro..... Can't help but think he'd have gotten flamed to a crisp if he posted that on a GM board.
Golf rolled down a hill, smashed into a car with people in it at a stop light...
Thank fully my daughter was not in the car...... pulled the parking brake a little too little, did not turn wheels into curb and left it out of gear..:bang:
Uh-oh. Glad daughter is OK...... Pics?? Is this a "Robbies Repair Shop" fix or an ICBC write off kinda thing?
Hey Cammer... they wrote it off for a headlight, fender and hood damage:bang::(, I will buy it back for 750bucks and repair it the Robbie Burns way..:eek:....Got pics on my camera, I will post them later...
Well then. There we go. I thought a Tacoma VW diesel swap might have been on the table. Or did you sell the tac.... can't keep up. lol.
