Hello
I have a LC100 Sahara 2004 which when you are driving through corners the VSC TRAC works at to low a speed. On a Hyundai Terracan I own as well, I go through the same corner faster, and have no issue with traction. Happens into left hand bends more than right hand bends. On the wrong surface this slow down would cause problems. This is an Australian model.
I would like to be able to disable it, or have people had similar problem and what was the problem. Was it slack in the rack pinion or specific sensor problems. Or other issue that solved it. Has anyone disabled it without disabling the ABS, and how did they do it. Frankly I don't think its needed on bitumen road driving
Regards
Regards
