Viscous Coupler - Reinstall or Toss?
Viscous Coupler - Reinstall or Not?
  • Reinstall
  • Don't reinstall
Results are only viewable after voting.
With an AWD truck if you loose traction at 1 wheel you loose drive to all wheels. With the VC in there, if you loose traction at 1 wheel the VC will transfer some drive to the axle that has traction in hopes of helping to drive out. I'd keep it.
I am looking for a viscous coupler for my 94LC. I am the only owner. The truck kicks out on slow turns, even screeches. I understand that is due to a defective viscous coupler. I'd like a new one, but if a used one were said to be good, I might take that. My mechanic wont install it unless it is new. He says he cant get a hold of one but i'm not sure i believe him. Thanks all for your help.
Impex might have it. New parts search — IMPEX JAPAN - https://en.impex-jp.com/parts/new/search.html?partNo=4133060010+
PartSouq doesn't
You might have to buy an entire TC to get one, but...
@slow95z
I'm regearing my transfer case. My viscous coupler was working fine before I pulled the case apart.
Now that it's sitting on my garage floor, I'm looking at it and thinking I might ditch it.
Thoughts?
i'll take it if you still have it. Thanks!
I ended up reinstalling mine. I recommend keeping it. Cheers.
If I get part time hubs and a CDL button and a pin 7 mod, I have to have early short axles or can I machine a groove in the long birfelds and if so does anyone know how may mm back from the first groove does it need to be. I’ve been hoarding good birfeilds.
Search is your friend: OGBeno post #21
Ya but how far back do they need to be cut from the original location?
"Ya but how far back do they need to be cut from the original location?"
Search is still your friend:
Post #106 "machine a new snap ring groove 13mm from the top of the 4/1994 birf or later"
