Vibration up front. Steering tablizer?
North Carolina
Hey all hope you can give me some help with this,
So the past month or two I've had this rapid but small vibration when doing about 60 and going to change lanes it does the vibration, but going in a straight line its hardly noticeable. It came around after i did a complete rebuild of my front axle. I've checked everything and it seems to check out and i put a fish scale on it and its about 15lbs ( Tightened it up some more for the bigger tires). But everything checks out and there's no play in anything so to me it just seems like the steering stablizer. If that is the case what is a recommend to replace it with. i have a OME and haven't had a problem with it till now but just seeing if there's better.
Thanks
Check your wheel bearings , check your steering arms are still bolted to knuckle and torque to 71 ft lbs, did you change your trunion bearings? Did you make sure all bearings changed that the race was fully seated
Things attributed to the stabilizer usually end up being tires, and can be worse with worn or loose bushings.
What kind of vibration? High or low frequency? Low would be more of a shaking than vibration. High could be a lot of things, from u-joints to loose body parts, weatherstrip, or engine skirts. Including bearings.
You can remove the stabilizer, it is not required. If the problem doesn't go away, that wasn't it.
Wheel bearings are good, And everything is bolted up. I did a complete axle overhaul and did the trunion bearings also. I made sure everything was seated when I put it back together.
It’s like a a rapid twitch to put it in a better perspective. It’s little movement and not violent at all. U-joints are good and nothing’s loose on anything. I’ll pull the stabilizer off this weekend after I do my LSPV value that blew out and started leaking fluid everywhere yesterday. And I’ll get back with they outcome of that
You can also swap (rotate) your tires around and see if anything changes.
When were the tires last balanced?
At 60 MPH, it was the first thing too come too me as well, sometimes it is the simplest of things.
Of note to the OP, depending on tyre brand, after new tyres are balanced and fitted, it can be as few as a couple of thousand miles before the tyres settle in and need rebalancing, then they are fine.
Regards
Dave
The steering stabilizer only dampens the steering input. Unless it's loose, I don't think it can affect the handling the way you're describing.
Sounds like the problem is in the wheels.
Rotated the tires and no change. Fronts crossed and tears straight up and no change in anything.
Tires were last balanced when I got brand new Goodyear mtr’s in September. They probably have no more then 5,000 miles on them. I’ll bring them up to get balanced if re-torquing the wheel bearings doesn’t work.
Throw the fish scale as far as you can, then re-torque your wheel bearings.
I’ll try that and see if there’s any difference.
Yeah that’s what I thought. But I was watching one of the youtubers I watch and he had the same problem I had and it was his steering stabilizer. Mine needs replaced regardless it’s 7+ years old and about time for a new one.
What’s a recommended brand for one with running bigger tires. Go with something else or stick with an old man emu?
Thanks to everyone giving out suggestions on what it could be. Hopefully it’s one of those things or something simple.
Could it possibly a bad tie rod end? I pulled those off when I pulled the knuckles off. But they still looked good when I pulled them off. Could be the vibration right there.
If your knuckle rebuild is good, that would be my first bet.
Sure. If you don't know their history, I'd replace them. A knuckle rebuild, New wheel bearings, and new TREs can make a truck drive like a new one.
I agree with the comment about removing the damper, at least to test and eliminate possible problems. It is not necessary of everything else is good
For wheel bearing preload, search for @Tools R Us method
I have the same Vibrations. Rebuilt the front axle a few weeks ago and now have a mild vibration at 60-65. Curious to find out what your problem is!
Ordered an OME steering stabilizer whether or not that is the problem. Should be here at the end of the week and be able to throw it on and see what happens.
Hate to tell you this but I have a 3 month old OME stabilizer on mine. I’m thinking it’s a different issue than stabilizer.
What wheels and tires, wheel spacers? A simple check for runout; jack the axle so the tires just clear the ground, spin the tires, watching the gap to the ground, is there significant runout?
It's the simple things that make life worth living...
As stated, the steering stabilizer cannot cause vibration or death wobble. However, the track bar is always a player in the wobble game. Check your track bar mounts for cracks and check the bushings for deterioration. Have somebody crank the truck and while it is parked and running, steer it from side to side while you get under the front and watch the upper and lower track bar ends for any play. If you see any movement, there's your bogey. It may be as simple as just needing to torque your track bar bolts. 130 ft/lbs.
