Good to know, how long ago were they replaced and was there visible movement.
Others did same, but said came back after a year or so.
Do you have sliders or running boards?
And, how about that spare tire?
All stock DD with running boards. Spare is very tight up under, filled with air while in place which makes for a very sung fit.
Sound effect from rough idle is coming from roof rack, it's my check engine light "sound indicator". I didn't pay extra for the indicator, but hey, it works better than check engine light....![]()
So far no vibration, not even from my roof rack "check engine sound indicator". Before calling this issue solved; {waiting on reset to take affect, burn through at least one tank of gas along with varying weather condition} then I'll make the call.
I'm happy no vibration sound.
***I am convinced the things that were vibrating were just symptoms of the problem and that the dirty throttle bodies were the issue.
I couldn't agree with you more, provided the thing(s) vibrating are in proper working order. The sound is a diagnostic aid alerting us, just not as specific as the check engine light code.
Throttle body has been common throughout this thread, as have other issues in the air/fuel category.
Many keep pointing to the part(s) vibrating, or old mounts. Which are to be considered, but rarely the root of the problem. For some it seems, they're very content removing a part or stuffing rags to stop harmonics, which really doesn't take advantage of this annoying but beneficial diagnostic aid SOUND.
I believe even with broken engine mounts; the 2UZ-FE engine should run at a very low vibration as designed. If not in most cases something needs to be correcting beyond just changing mounts/parts.
Your the type of owner I like buying from...kudos to you.
<<click to the left and see Rough idle & D vibration reduction tree procedure.
I had thought the slight vibration and rumble was normal on my truck. It was NOT. I was wheeling a few weeks ago and had my t-case knob shift over 3" to the passenger side and blew my center console out on the trail. I knew I had sheared a motor mount. The vibration didn't increase, nor decrease while driving. So I just thought I'll take it easy and not drive it hard on the street. I just replaced both motor mounts and discovered that BOTH were broken. So the motor was just resting in the cradle. **** There was substantial dirt and debris in the mount, which told us that it had been broken for quite some time.
***** You cannot tell if they are broken until you take them out.
