- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
I'd still say that is fairly slick rock (no pun intended). Either that or they have their tire pressure way too high. (Which they do look high in the video, but hard to tell.)
The white LX is mine, from last year, IIRC ran 14psi. For that obstacle lower would have been ideal, but Golden Spike is a long trail with a ton of big/sharp steps, so sidewall pinch is an issue. Air pressure is a compromise.
But I'm used to wheeling on mostly granite rock. The second video shows it well, the sandstone has been worn very smooth. Granite doesn't wear smooth like that, it tends to flake off or break. In this area, if you're spinning the tires like that you've lost traction. This could be due to being stuck, high centered, tires in a hole, PSI too high, or a layer of super fine dust sitting on the rock (makes it about as slick as ice).
You never spin tires like that due to too much traction. At least not where I wheel.![]()
I agree that Zuli Hill is worn, some other obstacles would be better examples, but don't have video handy. Not hung up, nothing is hitting ground but the tires, the angle/ledges are stopping progress. On the first bump attempt I touched something, likely the arm bracket, there is a rock under there that has taken out drive shafts, so Robbie looked to make sure I was going to clear before the second attempt.
I also most often wheel on granite, agree that it tends to come apart, making ball bearings under the tires, has much less traction than slick rock. The fun of wheeling in that area is the great traction, can drive at angles, hold lines, that you would slide right off just about anywhere else. If you haven't experienced it, there is little chance if explaining it to you.
The reason for the video is to demonstrate what the drive train is capable of, not nitpick the difficulty of obstacle or driver skill. A drive train that will soak up that abuse is not going to break on the street, unless it is weakened by other deficiencies. My guess the loads are much higher in that type of activity than anything that could reasonably be done on the street.
, wear tires, etc, lots of spectacular carnage on the trail, no street breakage.
