73 fj40 desmogged, rebuilt engine, trollhole carb, new pertonix electronic ignition, stock dizzy, original coil with ballast resistor. New rotor, cap and wires.
I set timing at approximately 13 degrees btdc. BB at bottom of window. Idles great, starts great. Put load or rev engine it falls on it's face and sputters.
My question is when I hook up vacuum tester up I'm showing 18 inches vacuum. When I step on accelerater it will drop fast. Is this the correct response? Never done this before with vacuum tester.
I have my vacuum tester hooked up to brake booster port.
I'm leaning toward a vacuum leak somewhere but can't find with conventional ways.
I also did set idle mixture. I dialed in till started to run rough and then backed out till started to run even again. Idle is at 650 rpm with my tachometer gauge tester.
Yes I have been reading my head off in FAQ and other threads.
Please any help would be great.
Thank you
btbuild
Thank you
btbuild
Might be worth a try.
