You actually got to chat with the Delta current control guy?
Interesting.
Bear in mind you don't want a "normal" high output alternator, you would be better served by a "high output/low RPM" alternator. While idling around or in stop and go traffic the engine RPMs may not be high enough to keep the fan running without draining the battery. Also keep in mind the power from the lights, heater blower, etc. that you may be using in the dark. A major reason I switched to a mech fan.
Well, if email == talking, then, yes, I've talked to him several times over the last few years. He can be hard to get a hold of though.
Has anyone run a FlowKooler water pump plus water wetter .
I had a vehicle that I could not make run cool. The PO had put a pump on it just prior to my buying it, so I worked with everything else. I was able to make it cool better, but not enough. I finally bought a Stewart Stage 1 water pump for it. Then I had a car that I couldn't easily warm up, but held it's temp no matter how hard I flogged it.Has anyone run a FlowKooler water pump plus water wetter .
Its a good idea to remove all the air from your cooling system before you add your coolant.
Better is to convert the system to be self-purging of air, and even better is to do so in a swirlpot. Both of those concepts are beyond what we're talking about here. Corvettes starting in the 60's used the former design. I can't say that I've ever seen a swirlpot on anything that wasn't a race car.Its a good idea to remove all the air from your cooling system before you add your coolant.
Has anyone seen AIRLIFT by UView ???????? must not work Ive had one for ten years.I use it every time it pulls a vacuum on my cooling system and fills my cooling system with out any air pockets.![]()
The lower hose was one I found at O'Riely's a while back. The shot near the fuel lines is to try to show engine placement for and aft. After having done a few of these I have noticed that the heater hard line clears that right rear coil pack barely if it is placed in a good compromised position. there is maybe a half inch of clearance there. not that usefull for those of you with earlier motors, but what the heck.
