- Joined
- Jan 6, 2012
- Threads
- 341
- Messages
- 10,935
Here is a pic of mine completed...
I think that pic is correct.thanks @White Stripe - I thought that my google skilz were good, but I could not find a "how to" on this.
I am thinking this is what you are talking about. pin 1 and 2 of the albright and hot power going to the controller.
No. You may want to put some sort of grease on the terminals to prevent corrosion though on the terminalsHey @White Stripe do I need to put this in a waterproof box? Can't find a definative answer; however, the stock box is definately not waterproof.
I was under the impression that the Albright took up the same if not less room than a 4 solenoid system.
Sure, the size of a single Albright contactor is much less than the four original solenoids. The problem is, the space you need to hook up all the wires to the Albright, plus the clearance you need between the controller plug socket and the Albright, underneath the cover. There are some photos of mine in this thread: Wiring an 8274 + Albright It was a tight squeeze for me.
I used the superwinch Albright with 3 pin controller. I found a wiring schematic online-you just need to search Google a bit. Real estate in the controller box is tight with a Albright so I used a crawlorado box with no hole and drilled a hole in the side using a hole saw.
8274 Warn Aluminum Winch Solenoid Cover
Basically they need to send you a replacement "W" without a hole. Contact Awl_teq here on mud and ask him to yell at the owner Trevor for you. I had a bit of issue with crawlorado as well, he did the exact same thing with me. Awl_teq knows the owner of crawlorado and will chew him out for you-he did for me anyway and I got the solid "W" about a week after that.Not impressed with Crawlorado vendor you linked. My order shows that I ordered the solid box, no hole, but they shipped the one with the hole right in the wrong spot!
I have called and emailed them, with no replies.
Guess I am going to have to file a claim with paypal. Sucks.
