It's really important to use the right filter number on the one 1HZ/1HDT motors, since it is a top mount filter, you need an anti-drain back valve built in. That way there will always be oil in your filter on cold starts.
As a side note, the YZZD3 updated part number should never be used on any of Toyotas diesel motors, as it is made to filter only a few quarts of oil, not a few gallons. They're also not made in Japan, they're made in Thailand, as are a lot of Toyotas new updated filter part numbers, one reason they're so affordable. Even Denso and Sakura are farming out a lot of their manufacturing to Chinese factories. It's important to buy quality filters that say made in Japan on them. It's a lot cheaper than a rebuild
