Use spring compressor to install lift?
Minneapolis MN
I have a [currently] stock 1996 80. Just finished the font axle rebuild and am about to begin installing a 2.5" OME lift (springs & shocks).
I know all the instructions say to disconnect everything and push down on the axles to remove the springs. But is there any reason NOT to simply use a spring compressor instead?
The reason I'd prefer to not disconnect everything is because of a ton of old rusty bolts that I KNOW are just waiting for me to break them. Especially the sway bar and brake line bolts. I'd rather not turn a four-hour two banana job into a twelve hour bolt extracting nightmare.
Thoughts?
Start at 10:21. These guys are qualified mechanics. Just some food for thought.
I didn't have to remove the swaybar bolts when I did mine.
I tried and it was way too much work, way too hard compare to just push the axle down.
Dang. So maybe a better question then is this:
What parts MUST I unbolt for this job, and which ones can I leave alone?
For reference, I was basically going to follow Slee's very detailed step by step guide. But maybe that's overkill for a 2.5" lift?
This video helped me the first time I dug into my suspension.
No.
Get some 6-ton jack stands from harbor freight. there's a coupon. 6 ton not for the weight rating but for the height.
jack up frame and put frame on jack stands at full extension.
Take off wheels.
I disconnected the sway bars. Maybe you don't have to, but i basically reached in with one hand and lifted out the factory spring, then reached in with one hand to place the OME spring.
yeah, with the bump stops in place. There is that much room to work with.
By the time i got done installing springs and shocks in the back, the rear diff was about 2" above the driveway, frame rails 2 feet in the air.
That video is great. But they make it look so easy on a rust-free truck.
Oh - and I have a set of four 6-ton jack stands. The frame is resting on two of them now, with the front axle hanging. I'm just apprehensive about little rusty bolts. Maybe tomorrow I'll just go for it and try not to unbolt anything unless I really have to.
I hoped to use spring compressors when I changed my springs. I was using strut compressors. That did not work. I ended up taking off the swaybar brackets, and just followed Slee's instructions.
there is no reason for spring compressors on an 80 series, just get the truck up in the air and push down on the axle and they will pop out. Spring compressors are really only used for struts. Don't buy the cheap harbor freight ones, get a quality set of spring compressors and use an air gun.
push down on the knuckle/brake area and they should come loose enough to yank out. If not, get a buddy to stand or "bounce" on the knuckle/brake area. If you're working alone, you can also sit on the brake and force your shoulders into the wheel well (totally uncomfortable, but it works). No special tools required.
Better to soak the crap out of old bolts, remove and replace than to let them sit there and get even further stuck over time.
I use ratchet straps to squeeze the springs abit . Bit backyardish but works for that little extra if your putting in taller springs and spacers . Like anything spring related can be a little dangerous though.
I used a spring compressor with my install but I have the single action one harbor freight sells. Ive had it for several years and it always has worked well. The cheap ones are really dangerous and ive seen them fail a couple times.
