Upgraded headlight's need ideas
Taylorsville Utah
Hi all.
I did a quick search but I didnt find the lights I was looking for, Anyhow, My dad needed some brighter headlight's on the 40, I suggested the replacement lights that replace the entire bulb and replace it with a new lens and it uses the halogen 9008 er something bulb's, Anyone have any infor on them? I saw a set on ebay a while ago.
Thanks :cheers:
you want Hella, IPF, Cibie 7" H-4's, with the stock wiring used 55/60 watt bulbs.
I run IPF's in all my round eye cruisers, LOVE them
I'll second the IPF lights.
replacing the headlights is only part of the fix. You can put in the brightest lights around, and good chance is they still wont be very bright unless you redo the wiring to the lights with a relay. All the electricity flowing to your lights goes through the switch and small wires.
I was running some nice halogens, and they were still pretty dim until I redid my wiring.
-Dustin
Thanks for all the responce, I forgot to mention my dad has a "painfull" rewire kit that was pro installed, Dont know if that make any differance?!?
I will pass along the info, I will check into the IPF's
Thanks again
-Dustin
I agree I run 80/100 H4 bulbs and they made a difference but then once i added the relays they were amazing.
IPF
I run 90/145's (almost five years now) when they puke, I will swap in 100/170's I picked up from ARB, as IPF no longer makes the 90/145's.
If you plan on a bulb beyond stock, use the IPF harness and relay system!!!
Good luck!
-Steve
even though cruiser switches may be able to handle the load, you will thank me later by adding relays for both your low and high beam circuits.
manny
I understand some people even run a relays for each individual off-road light...
65-fj45 said:
I replaced mine with Silvania Silver stars, they are a white light and work awsome.
did the same, much better.
